This is going to be a fun job
Just got the alternator off
All the rest of the manifold nuts came off no prob number 8 at the back of the manifold came out with the stud
Number 1 stud won't move with easy outs or the left hand drill bits
Had to have a quick go through the manifold just to see
No luck
Carnt split the 3 exhaust bolts tonight from above
So it's going on axle stands tomorrow
Going to drop the fluids (oil and water )
Once I SEPERATE the exhaust I will get the manifold and turbo all off in one I think
Then can get at the stud , hope it don't end up to have to be a heli-coil job
At least it will be a doddle to change oil filter with all that lot off
Thermostat looks abit of a sod to get at the bolts as well
Manifold studs are here ( thank you bongo shop ), gasket here ,rads here , water pump , belts and stat are at post office, think I'm going to order the stainless exhaust tomorrow, then if the exhaust bolts give me grief I can just cut it off
Going to remove winter valve as well ( do I just blank off the pipes to and from it ) & disconnect elec from switch
Turning into a big job just for a snapped stud
I'm on emergency call out for work this weekend aswell
Going to be a couple of weekends before its back on the road I think
