OEM Aerial fitment
e31shrew
OEM Aerial fitment
Post by e31shrew » Wed Feb 08, 2017 4:51 pm
Hi all
We have a 98 Bongo and wondering if anyone knows how to replace the aerial? Assume the plastic cap in the centre comes out but have used a sharp knife, and besides losing three fingers, it doesn't want to budge!
Any assistance gratefully received
All the best
Steve
V6 Scaglietti Bongolaise
Bongolia
Re: OEM Aerial fitment
Post by Bongolia » Wed Feb 08, 2017 5:20 pm
best of my recollection its secured by two screws either side. The centre remains untouched. They may be covered by little plastic covers, get :D them out with the edge of a stanley blade. Mind your fingers though. :D
Post by Bob » Wed Feb 08, 2017 5:35 pm
I've a good idea there is a 'Fact Sheet' on this. :wink:
e31shrew
Post by e31shrew » Wed Feb 08, 2017 5:52 pm
Thanks chaps. There is indeed a couple of screws either side. I'll hunt for A fact sheet first then give the other option a bash.
Thanks again
Post by Bob » Wed Feb 08, 2017 6:05 pm
Members' area, second one down.
To get the said area you need to click on the 3 horizontal bars, top left of main page, just under 2Gether insurance ad. 8)
e31shrew
Post by e31shrew » Wed Feb 08, 2017 6:09 pm
Got it. Thanks Bob. Looks like the small cap needs to be prised off and then use all six hands to catch a ball bearing as well as other bits and bobs
Post by Northern Bongolow » Wed Feb 08, 2017 7:44 pm
there is a small spring to catch too. use yer teeth to catch this. then when you have it in bits you will NEVER work out how it goes back together to get the 2 clicks to work correctly. ive done several and still would rather not.
top tip when putting it together use a bit of grease or vaseline, but i cannot tell you where for. :shock: :lol:
e31shrew
Post by e31shrew » Wed Feb 08, 2017 10:23 pm
Ooooer matron! Thanks again
Merlot man
Post by Merlot man » Wed Feb 08, 2017 11:20 pm
It's good advice to read the fact sheet and no need to remove the two side screws only the middle one but as northern bongolow said there is a spring and ball bearing that needs to be put back in place , if you loose them your goosed !
Best of luck
Brian
Post by Bob » Wed Feb 08, 2017 11:33 pm
Merlot man wrote:It's good advice to read the fact sheet and no need to remove the two side screws only the middle one but as northern bongolow said there is a spring and ball bearing that needs to be put back in place , if you loose them your goosed !
Best of luck
Brian
That's why you need Vasseline.
I'll get me coat. :lol:
