Engine Pre Heaters
Engine Pre Heaters
Does anyone have an engine preheater kit fitted to their bongo? I have seen them advertised by Kenlowe in the past. Also would it be possible to keep this connected while on a hookup at a campsite and then use the cooling system to keep the heater on?
Haven't seen them for years - you used to fit them into the bottom hose.
Can't see how you could use them to heat the van, because the water wouldn't be circulating through the heater matrix without the engine running.
Just looked up the website - it looks as if you can get them with a pump to circulate the water, so it could heat the van if you had the ignition and heater fan on.
Looks like you would need the lower powered one to use a 10amp supply.
