Hi all, just joined today, recommended by Jo at Haydn Alarms.
I have a 2.5 turbo diesel 1997, only had it for a few months,
if I can be a nuisance newbe, I bought A TM1 from Haydn and
want to wire the oil pressure sender to it, But cant seem to
the sender , can anyone put me wise.
many thank's Les
PS Haydn cant help either
oil pressure sender
Re: oil pressure sender
Not sure myself, but we have some red hot techie peeps on here who will be along soon, I'm sure.
Item 18-501 on the drawing is the oil pressure switch that is usually use as a feed on most vehicles and you should also be able to pick up an alternative supply feed on the instrument PCB.BUT I would get Confirmation from the Supplier/Manufacturer of the unit that it wont cause any complications .
many thank's Bob Geof Rita
I think I'm looking on the wrong side, took it for granted it would be offside(drivers side)
Les
Les
