Headlights Full beam not working
al & chris
Post by al & chris » Mon Nov 14, 2016 9:09 pm
Tonight just put headlights on to full beam and all went dark, put back on to dipped and back on again. Intermitant at first stayed on full beam for a while then darkness. Any ideas, could it be a relay ?
Re: Headlights Full beam not working
Post by g8dhe » Mon Nov 14, 2016 10:19 pm
Check the lamp sockets first! They have a habit of heating up and losing all the spring in the connectors, if so replace with ceramic ones from ebay.
http://www.ebay.co.uk/sch/i.html?_from= ... s&_sacat=0
Post by Bob » Mon Nov 14, 2016 11:11 pm
Do they come on if you use the 'Flasher' on the stalk?
That will give a clue if its the connectors or possibly the relay or the contacts on the stalk.
MalcW
Post by MalcW » Tue Nov 15, 2016 12:00 pm
g8dhe wrote:Check the lamp sockets first! They have a habit of heating up and losing all the spring in the connectors, if so replace with ceramic ones from ebay.
I would have thought it unlikely that both bulb holders would fail simultaneously. More likely to be the stalk.
Post by Bob » Tue Nov 15, 2016 12:28 pm
Again rare, but I have known both bulbs go, hence worth trying the flasher. :wink:
teenmal
Post by teenmal » Tue Nov 15, 2016 7:40 pm
al & chris wrote:Tonight just put headlights on to full beam and all went dark, put back on to dipped and back on again. Intermitant at first stayed on full beam for a while then darkness. Any ideas, could it be a relay ?
Owing to the fact that as you have said "it was intermittent" I would have a good look at the relays, they tend to get a wee bit damp and dirty around the Gills.
But don't rule out the bulbs first.
Post by mikeonb4c » Tue Nov 15, 2016 9:11 pm
I'm inclined towards the relays myself, but guess its a case of working through all the points raised above.
al & chris
Post by al & chris » Tue Nov 15, 2016 9:18 pm
Bob wrote:Do they come on if you use the 'Flasher' on the stalk?
Yes they do come on if using flasher, just when flick stalk forwards. Was intermitant for a couple of times now does now just darkkness when stalk flicked forwards. No high beam and no headlights.
Post by Bob » Tue Nov 15, 2016 9:58 pm
By any chance do you have spot lights fitted to come on with main beam?
If an extra relay wasn't fitted this could have burned out the contacts in the stalk.
And do I read correctly there's also no dipped beam?
Post by mikeonb4c » Tue Nov 15, 2016 10:02 pm
Ah - doesn't sound so much like the relay now. Stalk now the main suspect?
al & chris
Post by al & chris » Tue Nov 15, 2016 10:35 pm
Bob wrote:By any chance do you have spot lights fitted to come on with main beam?
No spot lights. Dipped beam as normal until headlights flicked forwards to full beam then dipped beam goes out as well as full beam not coming on.
Post by Bob » Tue Nov 15, 2016 11:20 pm
That's normal, with this set up dip will always go out when main is selected.
One or the other, not both together. :wink:
rita
Post by rita » Wed Nov 16, 2016 3:58 pm
To get the main and dipped to come on together you need to switch the dip on then use the flash operation, the dip will go out BUT when you release the stalk Slightly the dip will come back on illuminating both main and dip. This operation has been used for years against ignorant oncoming drivers, and really light up lonely unlit country roads.
Good Luck.
al & chris
Post by al & chris » Thu Nov 17, 2016 9:50 pm
Sprayed wd 40 into stalk contact area and main beam worked for a couple of minutes. Dirty stalk contacts? Or do they need to be replaced. Are they easy to get to and do I have to disassemble them to clean them.
Post by Bob » Thu Nov 17, 2016 10:14 pm
I'd try some spray contact cleaner, if that doesn't work the contacts are likely burned out.
Don't know how hard it is to remove the stalk but it shouldn't be too difficult, trim off the column and a couple of screws I'd guess. =D>
