no harm as spares, especially as you were after a simple LB set up. Useful if you ever want to add things in the future like fancy lights, beer chillerstevlor wrote:Phew, was dreading fault diagnosis this morning, but turns out it was just a weak connection to the fuse box from the leisure battery, so easily fixed. Unfortunately my bongo doesn't have electric blinds. In the VSR instructions it says that if this is the case I can use the two fuses for other things - but what else could I have? I think I'm ok with lights, stereo and 12v sockets tbh!
Simple Leisure Battery Setup
Re: Simple Leisure Battery Setup
Chris with BertieB
Does anyone know if rooster is still producing the circuit swap loom? Whenever I search for it on fleabay it shows 'ended'
									Why be the same as everyone else when, with a bit of effort, you can be different?
						- Jimbobvfr400
i bought one fairly recently but i didnt use ebay I messaged Karl direct on Facebook. if youmcan find an ended auction you could use the message to seller option to get in touch.
									Jamie, Caroline and the kids.
2002 V6 Aero AFT
						2002 V6 Aero AFT
