Wheel arch repair panels
Bongolia
Post by Bongolia » Wed Sep 21, 2016 10:43 pm
Read a post on here about adding in metal to the sprinter arches. Now I cant find it. Anyone point me in the right direction?
roosmith
Re: Wheel arch repair panels
Post by roosmith » Thu Sep 22, 2016 9:35 am
I don't know how to do links on here but if you search for "Sprinter arches pictures" there is a thread at the top of that search, with a step by step guide. Is that the one you are after?
rita
Post by rita » Thu Sep 22, 2016 11:06 am
The Sprinter arches are about 50mm shy in width, to get a good fit they need to be cut in the middle and a 50mm (approx.)fillet welded in.
Good Luck.
Bongolia
Post by Bongolia » Thu Sep 22, 2016 11:11 am
Got em. Ta
Post by Bob » Sat Sep 24, 2016 11:19 am
roosmith wrote:I don't know how to do links on here but if you search for "Sprinter arches pictures" there is a thread at the top of that search, with a step by step guide. Is that the one you are after?
You need to click on the address bar at the top of what you want to copy, press select all/copy then open where you want to put the link and click paste.
Someone may well explain it a bit better. :?
