Front Heater Problem
amac
Post by amac » Thu Jan 25, 2007 2:21 pm
Hi, I have just had my bongo serviced and had the heater resistor replaced since the heater was not working. It had worked for a couple of weeks and is now not working on any setting. Also if the A/C button is pushed in, it only lights up selectively when the heater knob is on 1 and 3 as I remember, could be 2 and 4, I will double check. Are there any obvious electrical connections/fuses I should check?
yoyomiyagi
Post by yoyomiyagi » Mon Jan 29, 2007 12:20 pm
Hi amac, have you made any headway with this? Just had the same problem occur: front blower stopped working (along with the roof) and the A/C light only lights up on setting number four. The only cause I can think of is that I attempted to plug in a laptop (with DC/DC converter) into the front 12v socket. Checked all fuses (the front and rear heater fan fuses appear to be under the bonnet by the way) and all seems alright. So has anybody else had this problem and is it actually a circuit weakness that exposes the relay to surges which may perhaps be permanently avoided by adding an extra earth and fuse? :?
Post by mikeonb4c » Mon Jan 29, 2007 1:24 pm
Have you read up on problems caused by heater motor seizing up as a result of a blocked 'drain which is supposed to carry water away from the gutter below the front windscreen. Once blocked, water overspills and causes deterioration of the heater motor. This in turn causes blown fuses and/or resistor (as far as I can remember). Its a known weakness in Bongos. I came across one for sale at a dealers that had this problem. I seem to recall one sympton is that the blower switch only works in some (or one position). Hope this helps (albeit in a negative way). I know some have managed to take the heater motor out and get it turning smoothly again.
Mike
yoyomiyagi
Post by yoyomiyagi » Mon Jan 29, 2007 1:41 pm
Hi Mike,
Thanks for the prompt reply! No, I just got the bongo 2.5 weeks ago and I'm just making my way through some of the forum topics/factsheets. Will clean out the gutter and test the fan with a 12v supply. Not sure why the roof is also affected :?: Do you know if translated service manual has decent wiring/circuitry diagrams? Looks like coughing up 70 squids for it might be necessary after all (just bought a fantastic physiology book for half that price and it is infinitely more interesting!). OK amac will let you know how I get on.
amac
Post by amac » Mon Jan 29, 2007 1:45 pm
All I managed to do this weekend was check some obvious fuses to no avail. The air-con fan will only operate on 1 and 3 and the heater fan is not working on any setting. My previous failure was the one where the heater fan operates on setting 4 only which was cured by renewing the resistor. Everthing worked as normal for a few weeks before I
I ended up in my current predicament.
Post by francophile1947 » Mon Jan 29, 2007 2:03 pm
Hi yoyomiyagi
Are you sure that the roof isn't working? I thought I had problems with mine until I remembered that the handbrake must be on. :oops:
antique
HEATER
Post by antique » Mon Jan 29, 2007 2:21 pm
hi take duct off the front of heater ,then try turning fan by hand if seized take the heater out strip it, wd40 the bearings get the motor spinning freely test it before you put it back ?
Post by mikeonb4c » Mon Jan 29, 2007 2:38 pm
Otherwise (am I right in saying antique?) you may keep blowing expensive electrical items to no avail). Good luck. Mike
antique
HEATER
Post by antique » Mon Jan 29, 2007 3:09 pm
hi thats right we learnt the expensive way ? that is when bongos first came into this country, there is normally a reason for failings, as you have all learnt keep the gutters clean ?[and down pipes ?]
yoyomiyagi
Post by yoyomiyagi » Tue Jan 30, 2007 5:46 pm
Oops you were right about the roof :oops: .. ok next fruitcake question: Can you tell me where the relay and front fan rotor are located (my service manual hasn't arrived yet). I am assuming they accessed from the bonnet.
antique
fan
Post by antique » Tue Jan 30, 2007 8:09 pm
hi go to members fact sheet for info , yes its under the bonnet open bonnet and look straight down
fordavefreda
Post by fordavefreda » Sun Feb 04, 2007 8:19 pm
hi guys, not been on here for a while, been having computer trouble :x
my front heater has packed in can any one tell me which are the fuses and resistors for it?
help appreciated, i'll do all the checks as described on this post...
cheers dave
