Gear box oil change
maxi_77
Gear box oil change
Post by maxi_77 » Wed Apr 06, 2016 4:46 pm
Has any one used a Pela type vacuum pump to extract the old oil from an auto gearbox?
White diesel Bongo
cmm303
Re: Gear box oil change
Post by cmm303 » Wed Apr 06, 2016 5:33 pm
I used a cheapo syringe type extractor. Worked fine. Think ATF is thinner than engine oil.
Bit over 4 litres to extract.
Chris with BertieB
mikeWalsall
Post by mikeWalsall » Wed Apr 06, 2016 8:49 pm
Have you checked .. some boxes have a sump drain plug .. my 1998 V6 has ..
Saying that .. it's far better removing the sump .. cleaning it .. and the magnet .. then removing the valve block filter and cleaning that as well (I put mine in the dishwasher) ..
Also remember when you have done all that .. refilled with Derron3 .. you have only changed around half of the fluid in the system ... the other half of the the mucky fluid is still in the toque converter ..!!
roosmith
Post by roosmith » Thu Apr 07, 2016 11:33 am
I removed the oil using a Pela before dropping the sump. Certainly made the sump removal a lot easier and cleaner!
It does take a while but so easy! I researched the different ones as the Pela is expensive however glad I spent the money on a proper one now I have it. I hope it is there and working in my garage for many years.
Alacrity
Post by Alacrity » Thu Apr 07, 2016 1:47 pm
mikeWalsall wrote:Also remember when you have done all that .. refilled with Derron3 .. you have only changed around half of the fluid in the system ... the other half of the the mucky fluid is still in the toque converter ..!!
I think that's a typo - it should read Dexron 3 or similar, these 'boxes are not fussy, just use a good quality oil not Comma c##p or stores own brand.
Also is using a Pela or other vacuum removal pump, do it when the oil is hot, it will then come out much quicker.
cmm303
Post by cmm303 » Thu Apr 07, 2016 2:29 pm
Oh dear, :oops: I had no idea Comma was that "good" :oops: In my defence it was the only ATF in a large container in the Halfords I called in on but what a waste of good money. Another ATF change? How soon?
Chris with BertieB
