air con belt loose
- mellon man
air con belt loose
Advice please, my air con belt is a bit slack. How do I adjust? Noticed two adjuster's on the top of the
pump unit ! What do I need to do??
Thanks..
Thanks..
Re: air con belt loose
Assuming it's a diesel, there is an adjustable tensioner:
http://lushprojects.com/bongopartsmk2/c ... o=.html#10
- mellon man
Thanks Yes it is a diesel
and it has 2 side way adjusters on the top of pump (look like larger versions of the one on top of the altimeter) do I need to tighten these? Cheers..
No. There is a tensioner pulley that needs a 17mm bolt unslackened at the front, then a 10mm bolt that you wind in clockwise to tighten. Starting at the top of the pump follow the belt towards the engine. There is a small pulley about 10cm in diameter about 30 cm along towards the engine from the pump.
1995 2.5 TD
small wheel in middle.
the 2 sideways adjusters you are talking about are for mounting the pump. There is another 2 below making 4 in total. Just leave them as is
1995 2.5 TD
- mellon man
Thanks again will have a go when time allows
What does the small pully do?
Also why are there 2 belts on the Altimeter?
the two belts drive the propellors for take off hehe. sorry couldn't resist.
1995 2.5 TD
- mellon man
Then It's Chocs Away is it!
Go round and roundmellon man wrote:What does the small pully do?
Chris with BertieB
You beat me to this point.....Fassi wrote:the two belts drive the propellors for take off hehe. sorry couldn't resist.
Alan...still plodding on....!
Yes, really Mikeonb4c should have been piloting this thread.alant54 wrote:You beat me to this point.....Fassi wrote:the two belts drive the propellors for take off hehe. sorry couldn't resist....I was going to recommend contacting Mikeonb4c who is our expert on Bongo flights........
1995 2.5 TD
