Battery drain
Battery drain
After weekend away drove back to rainy Dudley, 2 hours driving, low voltage alarm starts beeping on coolant alarm.
reading 10 volts.
Lights
wipers
blower
sat nav
phone charger
all on.
Peeing with rain.
Had to pull over at shop Bongo wouldn't restart.
Jumped it from leisure battery drove about with everything tuned off
charging at 13v
Any thoughts?
reading 10 volts.
Lights
wipers
blower
sat nav
phone charger
all on.
Peeing with rain.
charging at 13v
Any thoughts?
Always be ready for a Top Up!
Re: Battery drain
I guess you're measuring voltage across the battery terminals while running the engine.
13 Volts sounds a little low, 14 - 14.5 would be more like it, but one of our electrical chaps will likely be along soon.
Can you charge the battery overnight and see if that makes a difference, Baz?
Edit: 10 Volts at the battery is very bad.
Re: Battery drain
It was 10v on the alarm voltage reader, thinking alternator
MOT Booked for the morning will take battery out and charge.
Deep joy! and only had 45 nights away in it this year.
Re: Battery drain
Hopefuly she'll start and the garage can test the alternator.
Let's pray for an easy/cheap fix.
Re: Battery drain
Check both battery terminals and clean, also check the earth lead. If nothing obvious then it might be the alternator even if no charge light appearing.
Re: Battery drain
Just been out to have a mooch test across Bat 12.62v
Fired up 13.4 v
revs 13.8v
It was a very wet journey.
Fired up 13.4 v
revs 13.8v
Re: Battery drain
That certainly sounds better, let's hope it was just water getting where it shouldn't.
Re: Battery drain
13-8 after a start is still possibly low baz.
Re: Battery drain
Yup would agree with Ady, should be over 14 volts nearer 14.4volts under rev's. Float charging the battery the voltage should be around 13.6volts and this (float charging) is basically minimal charging too keep the battery maintained.
Re: Battery drain
bongobaz wrote:Float charging?
Almost a forgotten art, now that so few people have milk delivered.
Frank
They flew, I took up naturism
windywatson
- Tribal Elder
Re: Battery drain
I have a volt meter permantly across the battery monitoring its condition. When the engine is running I have a constant 14.2v being delivered by the alternator.
I would suggest that your alternator is at fault. Hopefully your garage will test this for you and highlight it if its on its way out.
Windy-Watson
2001 V6 Tin Top
2001 V6 Tin Top
Re: Battery drain
Sorry Baz! Float charging is where the charger is permanently connected and charging the battery all the time in which case the charger is set for 13.6 volts if it was higher then it would heat the battery and slowly cause the electrolyte to decrease over time, any less and the battery wouldn't be fully charged - its normally used for backup situations like emergency lights, that way the battery is always topped up, however it takes a looong time to fully charge if the battery is used significantly.
Re: Battery drain
THIS year ?...........D`you mean 45 nights already since 1st Jan !!bongobaz wrote:It was 10v on the alarm voltage reader, thinking alternator
Brian
Re: Battery drain
So you think my alternator is NFG?
How do i check it?
How do i check it?
