Gearbox Noise
Griff & Tracy
Gearbox Noise
Post by Griff & Tracy » Thu Jan 28, 2016 8:56 pm
Hi all
Could anyone give me some advice?
I bought a Bongo V6 about 4 months ago & for about 3 months there has been a strange noise. At first I thought it was coming from the front wheels but on closer listening it seems to be coming from the gearbox.
It only happens when drive is selected and I pull away. There is no noise when actually driving. It sound likes some kind of motor is kicking in. It doesn't happen in reverse just when I pull away - even when the engine is warm.
Any advice appreciated
Griff
wonkanoby
Re: Gearbox Noise
Post by wonkanoby » Fri Jan 29, 2016 10:13 am
is the a/c on
Re: Gearbox Noise
Post by Bob » Fri Jan 29, 2016 10:33 am
If you pop a rough location in your profile someone near you might take a listen or we can likely recomend a good Bongo Garage to help out. :wink:
Simon Jones
Re: Gearbox Noise
Post by Simon Jones » Fri Jan 29, 2016 1:47 pm
I sometimes get a whirring / squeaky noise from the gearbox when pulling away when cold but its fine when hot.
Griff & Tracy
Re: Gearbox Noise
Post by Griff & Tracy » Fri Jan 29, 2016 6:48 pm
I've updated my profile location - We're in Stockport
Thanks for your replies - I'll let you know if it stops or I work it out
Re: Gearbox Noise
Post by Bob » Fri Jan 29, 2016 7:36 pm
Ah, Stockport. :D
That gives you Wheelquick, in Wigan, and Adrian at (I think) Jap Direct, in Bury.
Mike will confirm this. :D
Re: Gearbox Noise
Post by mikeonb4c » Fri Jan 29, 2016 7:50 pm
Bob wrote:Ah, Stockport. :D
I can confirm Adrian is in Bury. Then again if its a gearbox problem these guys might fit a replacement and/or send a faulty one for rebuild by a specialist but i'm not sure how much they would muck around with the internals themselves.
Griff & Tracy
Re: Gearbox Noise
Post by Griff & Tracy » Fri Jan 29, 2016 11:05 pm
Thanks - both not too far away
I will them both a call & see what they say
Re: Gearbox Noise
Post by mikeonb4c » Fri Jan 29, 2016 11:12 pm
Griff & Tracy wrote:Thanks - both not too far away
Adrian is a great guy. He'll tell you straight what he can and can't do.
