Probably common knowledge but these things can effect your MPG on a petrol (there could be more):
Air filter cleanliness
Spark plugs
Oil
Tyre pressures
Tyres themselves (some fair worse than others on fuel efficiency)
Badly aged spark plug leads (the sparks cause deposit build up/ spark resistance)
Driving style - 55mph will give you the best mpg, at 70mph expect 20-25pct less mpg
Might be worth you putting a can of BG44K through the system (in the petrol tank so it is very easy). I rate it for petrol and Diesel (Diesel version is BG244) It cleans deposits from valves, combustion chambers, pistons, fuel lines etc. Read up on it the vast majority of users notice a difference, of course use it at your own risk/consideration but I rate it highly with zero negative effects.
Available on Amazon or Ebay (£23.00):
https://www.bgprod.com/catalog/gasoline ... m-cleaner/
Not saying you will end up with 36mpg ! But it all helps.
I use Millers Petrol/Diesel Eco max as well in every tank. This is less potent than the BG44K kind of cleaner (it is an octane/cetane booster with cleaners so akin to putting 97 RON petrol in or Supreme diesel but a
MUCH cheaper way of doing it, you just poor a measure in the tank, easy.) but I find my vehicles run smoother and quieter with the suggested amounts in the tanks. It is not a small difference on the Bongo. (quieter, smoother and more power)
Again Amazon or Ebay (about £10) :
http://www.millersoils.co.uk/automotive ... sector=Car
Gives you something to think about.
I get up to 43MPG on a long run with a diesel Bongo. Significantly less on short stop/start journeys but I do not do many of those in the Bongo thankfully.
I bet you could eat your dinner off the insides of my engines.
They call me light foot.
