Bleeding funnel?
Bleeding funnel?
Hayden's bleeding tutorial, where can I get that funnel and nipple from. Anyone know?
If you have to buy them separate, what size do I need?
Ta
Damien
Ta
Damien
Toyota Alphard - Bongo spirit
Re: Bleeding funnel?
I was thinking about using water butt connectors.
will fit 13mm ID hoses.
Can convert any clear container into one.
The bleed hose is smaller than 13mm ID, probably more like 8 or 9mm. I've used some of the fast-fit plumbing fittings which allows option of an on/off valve.
- helen&tony
I have used a jug and tap...there's no need for gloves, and no risk of burning fingers : http://igmaynard.co.uk/bongo/forum/view ... ap&start=0
There a definite pipe size?
Ready to buy tap and hose.
- helen&tony
From memory10mm
From memory10mm
- helen&tony
Yup...just checked...10 mm
- helen&tony
8mm is too small...plenty of 10 mm on eBay
