Front interior fans stopped working
Any ideas on where the fuse is?
Re: Front interior fans stopped working
All wiring, fuse and lamp info here http://www.g8dhe.net/bwm
if you click the top right tab marked search, then type in resister, or front and fans lots of threads will pop up, click on each one and have a read. put AND between each word, it helps the search find all the key words in a sentence.
its a common fault with various fixes depending on which bit has popped, it also depends what age the bongo is and whether its got the old style controls or the newer digital controls.
