Buying and Fitting new rear brake pads
Hi All,
Had some new tyres fitted yesterday and realised the rear pads were really low. Cash is tight and i have done this kind of thing before so I have decided to fit them myself. I have managed to get a full set off evilbay for £18.95 including delivery.
Im going to attempt next week does anyone have any words of wisdom/help please?
Im going to video myself so I know how I took them off so I can work out where everthing goes when putting back together. If im successful I will video the other wheel in a tutorial style if there is anywhere to upload for future people.
Also has anyone ever bought off Niponkev on ebay? His prices are way cheaper than anywhere else and his feedback great. Also so far his communication is great.
Your help is much appreciated.
Many Thanks.
Many Thanks.
Brakes
thanks for that but are there any other words of wisdom from anyone who has done it and has anyone ever bought off the ebay bloke?
Brakes
Well the pads came in one day! They look great ??? Got the fact sheet and about to go and fit them. Bargain price and good service off the ebay guy who has loads of cheap bongo new stuff.
Brakes
Well I have jsut read the fact sheet and Im scared!!!! Front dont sound too bad but the rear hmmmmmm. Oh well in for a penny. I thought the price and service off the internet guy was good lets just hope they fit and work. Wonder why the motor has to be in neutral, Im a bit dubious about no handbrake or gear with the rear off the floor......
Oh well Im just going off to pray to the brake gods and then have a go...wish me luck, i maybe posting later "how to drive a 3 wheeled bongo"
Choc the wheels
Choc the wheels as in stick big pieces of wood in front of them????
I've bought myself some axle stands (as advised by BongoBits) for when I do mine (and of course chock front wheels as well)
Some other tips I picked up on BF and from Bongobits involve the brake fluid reservoir.
1) loosen the reservoir top so that when you push the slave piston in and fluid wants to back up through the system, there is no air/back pressure preventing it.
2) It follows from (1) but Dandy (I think) advised pullng off some fluid from the reservoir at job start so you dont get overflow when you push the slave piston back in (brake fluid dissolves paint and is all round nasty!)
3) When you pump the brake pedal to settle the retracted piston back on to the pads, do it in short movements as if you make the master cylinder piston travel below its normal travel, you may wreck the seal and have to overhaul the master cylinder, bleed brakes etc etc
4) While doing (3) make sure your reservoir level doesnt drop and let air into the system!!
Now I'm talking from the book of theory (not having done it yet) so if a practical Bongo DIY mechanic wants to add/amend the abov, please do!
Good luck
Mike
Good luck
Mike
