Temperature Gauge stopped working
As above what's first thing to check?
Tried search on here.
Always be ready for a Top Up!
Re: Temperature Gauge stopped working
If it's a diesel there's a sender unit front drivers side top of the engine.Try cleaning the spade connector for the wire but sometimes the rivet can work loose and you'll need a new unit.If you look at this thread.
http://igmaynard.co.uk/bongo/forum/view ... =3&t=69358
Excellent advise from Ady aka Vanessa aka Northern Bongalow.
Whip off the spade connector and short it to earth, gauge should go to full hot (from memory).
That should tell you if its the sensor.
Just had a, look spade connector in place however the other end of the 6 inch wire is adrift with a red connector . Where does this go?
Not easy working in the street as the gas main is being replaced, lorries and holes everywhere will have another look when its quieter.
it goes over the front of the rocker cover baz, if you go to the passy side and find the alternator wiring harness, a single wire runs up towards the front of the head then jumps over to the drivers side to marry up with the end you have found.
sh&t its dark now, ------- sorry.
Thanks Ady found the wire. patched a piece in.
Ignition on, spade to earth, gauge went to hot as suggested by bob.
Put it back on and ran for 10 mins, gauge did Bog all. Its the sender you put in yonks ago was hoping it was all right as the wire was broken at a connector. The original seems quite thin .
Not been a good day for me. but there you go.
it possibly isnt hot enough after ten mins baz, take it for a spin.
On my old blue Bongo when the temp gauge didn't work it was identified as the Thermostat stuck open.
bazzes wont be stuck, its never parked up. how many days have you been away this year baz ???. may be its worn out.
190.
Getting stir crazy can't get away as they are changing gas main and access is needed.
So i thought i'd do the odd jobs.
