HELP: Low tickover U/S - can you identify these parts/pics
Re: HELP: Low tickover U/S - can you identify these parts/pi
Post by mikeonb4c » Wed Aug 26, 2015 10:49 pm
Northern Bongolow wrote:repair the broken stub by getting one of these.
https://www.google.co.uk/search?q=high+ ... PdFxcaM%3A.
take off the airfilter pipe, the filter lid end, then put your hand inside. drill out to fit dia of valve, screw a nut on to valve so that the valve is trapped onto the big black pipe wall, then cut off valve top to length, you should be left with a short stub to re atatch the thin pipe and one way valve.
Can't seem to find those on eBay etc. I presume it's valve needs removing as its only a means for making up a connection stub for the relevant small pipe/tubing.
Post by mikeonb4c » Wed Aug 26, 2015 11:31 pm
Provided I can source the right type/size I wonder if a suitable barb coupling might do:
http://www.pneulinesupply.com/products/ ... ub_id=3567
I could tap a thread into the plastic then araldite the coupling into place. Would that work maybe?
Post by mikeonb4c » Fri Sep 04, 2015 1:38 pm
Well I managed to re-make the vacuum pipe connector, using the brass barb fitting from the silencer of one of my old model aircraft engines (its used for fuel tank pressurisation tube connection). However, its made no difference to the tickover raising function either for cold start or when aircon is on. Using a mechanics stethoscope (hurrah, my ebay purchase at last finds a use!) I think I've ascertained that the white connector/solenoid is working (it seems to energise when ignition switched on and I can hear a clear click) but the black connector one does not (the faint click I can hear is probably just carry-over noise from the white one activating).
So.....any thoughts on how I might proceed from here? When I think of it, the cold tickover lifter shouldn't be connected with the vacuum thingie as I'm sure the throttle gets moved before engine is started if you switch ignition on from cold. Is the vacuum thingie connected to some other completely different function maybe?
Post by Northern Bongolow » Fri Sep 04, 2015 9:12 pm
the throttle thingy will only preset the throttle if the engine is not running IF your bongo holds its vac, most drop their vac soon after the engine is turned off.
take off the solenoids connect a bit of pipe to it then put 12 volts to it, its only a switch but is polarity concious.
Post by mikeonb4c » Sat Sep 05, 2015 12:04 am
Northern Bongolow wrote:the throttle thingy will only preset the throttle if the engine is not running IF your bongo holds its vac, most drop their vac soon after the engine is turned off.
Thanks Ady. Can the solenoids be removed without having to remove the centre section of the engine cover? Also, I tried sucking on the pipe to test the effect of a vacuum but it had no effect. This seems one of those Round Tuit jobs as the benefit of having the tickover adjustment seems hardly worth the pain of getting the system working! :roll:
Post by Northern Bongolow » Sat Sep 05, 2015 7:05 pm
i will see you in a field mike before winter, maybe silvergale beer fest if your up for it.
they are easy to remove in seconds, BUT can break in half a second if you dont do it right, the little securing clip holds it to the mounting plate, or there are 2 bolts that hold the mounting plate to the engine.
the 2 nearest you in the pic below are the ones your concerned with.
https://www.google.co.uk/search?q=mazda ... 1wYX1fM%3A
Post by mikeonb4c » Sun Sep 06, 2015 12:38 am
Northern Bongolow wrote:i will see you in a field mike before winter, maybe silvergale beer fest if your up for it.
Cheers Ady that's encouraging. I wonder if I should try and get over to you for a cuppa and a looksie at some point. Trish won't thank me for getting all techie when we're supposed to be camping, and I suspect we won't make Silvergale anyway. If she's that keen she could join me over your way. Being honest, this is not an urgent thing esp as I have that throttle lock cruise control which is very handy as a manual device for raising the tickover if I'm ever bothered by it (been a really useful device in that respect :-) ). But I'd like to get it sorted at some point because I like to keep the old girl 100%
Fassi
Post by Fassi » Sun Mar 06, 2016 7:02 pm
Just a bump for this and to see if it was resolved??
cheers
1995 2.5 TD
Post by mikeonb4c » Sun Mar 06, 2016 7:28 pm
Nope. Even my mechanic was unenthusiastic about tackling it, reminding me that his time was my money. And since its a minor irritation only, its gone on the B list for attention. In my case, I have a manual 'throttle lock' kind of cruise control which allows me to lock the throttle pedal at any position. This gets me out of trouble as I simply set it to run a slightly high tickover when required. Since the unit rests by my left arm on the centre console, its very easy to do this in any situation. I would like eventually to get the original units working again properly but I think it will need help from The Great Ady in order to achieve that.
