I have a strange and mysterious case of coolant fluid going missing on a regular basis.
No sign of leakage anywhere, no oil in the fluid when I top up, no sign of water in the oil, etc etc.
Any ideas gratefully received
Adey
True, and the leak can be out of sight and may evaporate before you can spot any sign. One technique you could try is putting u/v dye in the coolant and buying a cheap u/v torch to see if any suspect areas start to glow in u/v light.wonkanoby wrote:might be water pump
they have 2 holes one on side one bottom were they weap
As Gasy has said, that's a lot to be losing without signs of wetness (more than a pinhole leak I'd have thought, possibly water pump but falling to ground / blowing away in the wind but I'm not familiar with that).adey205 wrote:Seems to be roughly a litre per journey to work and back, so approximately 35 miles ?
He's written some good stuff though, and inspired some great song writers and performers.helen&tony wrote:Hi
Mike
In answer to your "Donovan", here's some "Dylan"...(in answer to your blowing in the wind):
https://www.youtube.com/watch?v=vWwgrjjIMXA
Actually, I can't stand Dylan...but there you go....
I might have said that about Cat Stevens or Jimmy Cliff, but Donovan?...................helen&tony wrote:Hi Mike...
Yes, I thought Donovan was an imitation...but EVERYBODY said they were "inspired" by Dylan...if they didn't , then they weren't "in with the in crowd"...I just think he's an arrogant twerp!
Dear moderators. Since the bit of humour in my post and that Helen has referred to has been removed, you might want to remove this and the other off topic posts in order that future readers aren't left confused. Thanks.helen&tony wrote:Hi
Mike
Yea righthelen&tony wrote:
Mike...the Donovan reference was on another thread...
