lumpy running
lumpy running
Hi All, Noticed lumpy running between 30/40 mph all other speeds
runs smooth? 2.5 diesel
thanx
thanx
Re: lumpy running
Has this suddenly started happening or is it a gradual onset? What happens if you put your foot down? Any black smoke? Does it drop a gear and take off well. Etc. Need to get a feel for what your problem is.
Re: lumpy running
No smoke pulls away smooth has been noticed over about three weeks
owned 7 years never changed glow plugs.
Re: lumpy running
Faulty glow plugs might give lumpy starting from cold but shouldn't bother a warm engine. Gradual onset suggests its worth working through cheaper/simpler things: air filter, fuel filter, banjo filter in that order. If they've not been done for a while they're worth doing anyway. If problem persists, then start looking at fuel pump I reckon. But others more techie than me may have other thoughts. Good luck, keep us posted.ribbleman wrote:No smoke pulls away smooth has been noticed over about three weeks
Re: lumpy running
Regular servicing not done banjo filter will check it.
thanx
thanx
Re: lumpy running
ribbleman wrote:Hi All, Noticed lumpy running between 30/40 mph all other speeds
thanx
It could be the heater relay dropping out, does this only happen when Cold or is it constant.
Re: lumpy running
Seems to be all the time
Re: lumpy running
Hi All, progress report just returned from hols round western isles,
lucy never missed a beat 1500 miles cleaned banjo filter was quite
clean very happy.
clean very happy.
Re: lumpy running
Great news. What do you reckon had been causing it?ribbleman wrote:Hi All, progress report just returned from hols round western isles,
clean very happy.
Re: lumpy running
Could have been fouled injector cleared after good run?.
Or perished pipe from air intake to top of fuel pump.
Re: lumpy running
Hey ho at least it's fixed itself.ribbleman wrote:Could have been fouled injector cleared after good run?.
