Project - Retrim and new paint
Moderator: Ian
Re: Project - Retrim and new paint
Has the roof gone back to white ?
The green sides look cool
I'd like to do my roof and the sides around the windows in Matt black
The roof is now the same colour as the main body (silver grey).
Gasy wrote:Has the roof gone back to white ?
- Tribal Elder
What's the chin spoiler from?
Are you going to the Stourport bash Puma931?
would be good to check it out properly, it's looking great
.......... cycling more.
- Tribal Elder
Ah, a T4, just read back through.Mark Elvin wrote:What's the chin spoiler from?
What was is like to fit?
can i ask were you bought the rustoleum
I modified one of theseMark Elvin wrote:What's the chin spoiler from?
http://www.ebay.co.uk/itm/VW-T4-TRANSPO ... 1c486c0d86
Yes, I ordered 8m and fitted it, but got stuck at the back as it was too tight to fit and not enough space to hit with a mallet, so I did not bother with the final part above the tailgate.TheStinkyHippy wrote:Did you replace the rubber around the roof in the end?
http://www.woolies-trim.co.uk/p-1606-fl ... -seal.aspx
wonkanoby wrote:can i ask were you bought the rustoleum
Paint: Rustoleum Combi Colour which was applied with a 4 inch roller brush.
Web link regarding roller painting process tips etc - http://forum.club8090.co.uk/viewtopic.p ... start=2655
I bought the paint from: https://www.promain.co.uk/product/rusto ... oss-id1190 and 2.5 litres should be enough to do a van (same colour) or 5 ltrs if a colour change. Thin down with white spirit (4 parts pain and 1 part thinners)
Best roller brush to use: 4 inch mohair roller. I tried foam rollers but got loads of air bubbles when painting http://www.ebay.co.uk/itm/321539611467? ... EBIDX%3AIT
Pain trays: Wickes sell cheap clear plastic trays (5) for about £2.50
I sprayed the green bits with plasticoat paint from Hobbycraft as other aerosol paint reacts with Rustoleum.
YesTheStinkyHippy wrote:Did you also use Rustoleum roller on the roof?
- Tribal Elder
Did you try loosening off the AFT nuts that hold the brackets to the roof, allows you to lift the rear edge slightly.Puma931 wrote:Yes, I ordered 8m and fitted it, but got stuck at the back as it was too tight to fit and not enough space to hit with a mallet, so I did not bother with the final part above the tailgate.TheStinkyHippy wrote:Did you replace the rubber around the roof in the end?
No
Mark Elvin wrote:Did you try loosening off the AFT nuts that hold the brackets to the roof, allows you to lift the rear edge slightly.Puma931 wrote:Yes, I ordered 8m and fitted it, but got stuck at the back as it was too tight to fit and not enough space to hit with a mallet, so I did not bother with the final part above the tailgate.TheStinkyHippy wrote:Did you replace the rubber around the roof in the end?
A few questions regarding your purchase of the roof rubber seal:Puma931 wrote:Yes, I ordered 8m and fitted it, but got stuck at the back as it was too tight to fit and not enough space to hit with a mallet, so I did not bother with the final part above the tailgate.TheStinkyHippy wrote:Did you replace the rubber around the roof in the end?
1/ was 8mts the right length to buy?
2/ is this a like for like replacement or is it different in any way?
3/ is it not possible to undo the bolts on the back of the roof and lift it a bit to fit it on?
4/ is it a good fit?
5/ what was the length of delivery?
My Bongo has just gone in for a respray and the rubber is looking shabby and cracking in places. I want to replace mine to finish it off.
I can, I do, I did.
