Bought our wagon in November with a good side conversion already in place. Now looking to tinker a little to make it ours.
Water supply:
At The moment it's got an external whale water supply which means we need to stop and have the container outside. Doesn't really suit us and I'd rather have a smaller container inside. Can I just use
Something like http://www.ebay.co.uk/itm/WHALE-12V-DC- ... 4ae7e0600c and rewire from the tap switch and the 12v leisure supply? I reckon I can get a slimline 10l container. That will do us fine. Waste water goes through a pipe to drop underneath.
TV:
12v TV currently runs off a the cigarette lighter so is running the starter battery. Always a bit nervous and the TV has a voltage warning which stops if it thinks the battery is draining, as. A result it's rarely good enough for a whole film. Starter battery has always been fine though. I've got a switched 12v live from the leisure battery tucked in one of the cupboards. Can I fit a junction box then simply cut the end off the cigarette lighter connection and wire it into the junction box?
I'll try and add photos tomorrow. So far I've switched the normal alloys for rx8s and got a set of toyo r37 tyres off an outlander 4x4 which are working brilliantly. In for an early mot and service soon before a euro trip so starting to feel like ours
