EGR System blanking
al & chris
EGR System blanking
Post by al & chris » Thu Mar 26, 2015 1:15 am
Thinking about blanking off the egr system and looking at old posts looks like quite a few of you have done this in the past.
Is anyone now having problems after doing this. Reading other posts on the web looks like there could be a link to blanking off and turbo problems, or is this just rubbish. Looking long term and high mileage could there be any link?
Re: EGR System blanking
Post by Bob » Thu Mar 26, 2015 1:21 am
Mine was blanked off soon after we got it 7 years ago, no probs so far, and we tow a caravan.
Contact Allans in Plymouth for plates.
Tony x
Post by Tony x » Thu Mar 26, 2015 6:23 pm
Well worth doing for a bit of mid range boost in power plus a recent post suggested it makes the engine less fussy on the oil you might use.
Engine will generate a bit more heat but this should not put you off as it won't overheat due to a blanked of EGR
Gasy
Post by Gasy » Thu Mar 26, 2015 6:33 pm
Is there a step by step guide for fitting these
Going to do mine soon
al & chris
Post by al & chris » Thu Mar 26, 2015 7:09 pm
Tony x wrote:Well worth doing for a bit of mid range boost in power plus a recent post suggested it makes the engine less fussy on the oil you might use.
Any other advantages/disadvantages people know of. How much hotter will engine run.
jimmo62
Post by jimmo62 » Thu Mar 26, 2015 7:15 pm
Gasy - there is a fitting guide here http://www.allansvehicleservices.co.uk/shop/
I have not done this myself so can't comment on the accuracy of the guide though.... But Allans seems to have a good reputation
Post by Bob » Thu Mar 26, 2015 7:34 pm
Very good reputation. 8)
briwy
Post by briwy » Thu Mar 26, 2015 9:10 pm
There's a few pictures here of ours when I did it. Later model but basically the same layout.
http://www.igmaynard.co.uk/bongo/forum/ ... t=blanking
Post by Northern Bongolow » Thu Mar 26, 2015 10:07 pm
best thing ive ever done to my motor. also diverted the crank/rocker cover breather pipe, this goes into the air intake pipe at the rear of the head, made mine like the old mini,s the pipe goes to ground level. all this makes the engine breathe clean fresh cooler air resulting in a cleaner burn once warmed up and a better bang as the cooler air is denser.
115000 miles and no crud or oil leaks, plus my engine oil and filter now last 2 years. 8) 8) .
Diplomat
Post by Diplomat » Thu Mar 26, 2015 10:41 pm
I've got a feeling this might inspire a few of us to undertake a fairly simple spring project, even if we are of the 'if it ain't broken..' school.
Frank
They flew, I took up naturism
al & chris
Post by al & chris » Thu Mar 26, 2015 11:07 pm
Northern Bongolow wrote:best thing ive ever done to my motor. also diverted the crank/rocker cover breather pipe, this goes into the air intake pipe at the rear of the head, made mine like the old mini,s the pipe goes to ground level. all this makes the engine breathe clean fresh cooler air resulting in a cleaner burn once warmed up and a better bang as the cooler air is denser.
So diverting rocker breather should offset slightly higher engine temp caused by blanking off?
bongoroy63
Post by bongoroy63 » Thu Mar 26, 2015 11:26 pm
Sorry for my ignorance but what is an EGR???
I can, I do, I did.
Simon Jones
Post by Simon Jones » Thu Mar 26, 2015 11:29 pm
bongoroy63
Post by bongoroy63 » Thu Mar 26, 2015 11:35 pm
Thanks Simon. Just had a quick look at the link and it seems a bit heavy for this time of night. I'll read it and digest it at a more appropriate time!
I can, I do, I did.
Simon Jones
Post by Simon Jones » Thu Mar 26, 2015 11:39 pm
Yeah, I gave up after the first paragraph :)
