Cigarette lighter fuse
pistonbroke
Post by pistonbroke » Sat Mar 21, 2015 9:09 am
My Bongo manual tells me how to wash the vehicle, even how to drive it in long grass, but no wiring diagram. Could anybody know which fuse protects the cigar lighter, please?
Gasy
Re: Cigarette lighter fuse
Post by Gasy » Sat Mar 21, 2015 9:13 am
Fuse 8 next to drivers knee 15amp ( starting top left )
Also does radio and elec wing mirrors
Think there is also another fuse built into the cigar lighter bit
1. Cabin 10A
2. Hazard Lights 10A
3. Brake Lights 15A
4. Central Locking 30A
5. Horn 10A
6. Blinds O/S 15A (if fitted)
7. Blinds N/S 15A (if fitted)
8. 12v Power outlet, Radio & Electric Mirrors 15A (if fitted)
9. Engine Management System 15A
10. Dashboard 15A
11. Indicators 10A
12. AFT Roof 30A or Electric Sunroof (dayvan) 20A
13. Rear Wipers and Washers 20A
14. Electric Windows 30A
15. Front Wipers and Washers 20A
16. Aircon 10A
17. Sliding Door 15A
18. Glow Plugs 10A
19. Blank
20. Blank
21. Additional Equipment 30A
22. Rear Heated Window 30A
Simon Jones
Post by Simon Jones » Sat Mar 21, 2015 10:06 am
Print off the fuses factsheet and keep it inside the owners manual in case you need it when out and about: http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
The fusible link on the rear of the socket is the grey wire that can just be seen at the back by the connectors. In theory you won't be able to blow this as the regular one should blow first.
Post by g8dhe » Sat Mar 21, 2015 10:35 am
Wiring diagrams ( needs flash) and fuses etc. Here http://www.g8dhe.net/bwm
pistonbroke
Post by pistonbroke » Sat Mar 21, 2015 10:08 pm
thanks. Will be able to charge stuff up now,
Post by Northern Bongolow » Sat Mar 21, 2015 10:21 pm
g8dhe wrote:Wiring diagrams ( needs flash) and fuses etc. Here http://www.g8dhe.net/bwm
you only need the wiring diagrams if you have had a flash mate. [-X #-o #-o #-o
Post by g8dhe » Sat Mar 21, 2015 10:37 pm
That's quite true Ady!
