low coolant alarm coming on
al & chris
- Tribal Elder
Ok twice now low coolant alarm has come on whilst driving. The alarm slowly comes to life light on, stays on for a while about 20 seconds second time longer first time then goes off. No coolant loss and no temp increase with TM2.
Thinking it could be earth or something?
- helen&tony
Re: low coolant alarm coming on
When starting, or after a while?....
al & chris
- Tribal Elder
After a while. We do have the usual chirping when starting but this is on constant.
David Edwards
Take the screws out and either replace or give em a really good clean, happens with mine now and again.
- helen&tony
As David said...plus check earth, and other connections etc.
- haydn callow
Yep, try all the above first, please report back.
hi haydon
mines doing the same every now and then
touch cloth scenario when your on the motorway
stays on or flickers - then goes off
I think its prob the screw getting coated etc
I have never changed it
if I send you the funds - is it possible you can send me a replacement
also - MY BUZZER - DOESNT BUZZ - no problem because it was annoying - but my led still works
was this ever reported as a problem ?
thanks
andy
thanks
andy
I would imagine that you would like this function to work properly, if its annoying its indicating that there is a fault IE lack of coolant in the header/expansion tank etc .andyb36 wrote:hi haydon
thanks
andy
hi teemal
the alarm works fine - but only with the led
it flashes bright enough to get my attention straight away
in fairness - if the bulb went - I wouldn't be so happy - I would need the buzzer
but I do check its working ok every time I start her up
no fear there - I would have a new one on order as soon as it didn't flash on start up
andy
andy
- haydn callow
I doubt your problem is a dirty screw (always wanted one of those). Make sure level is o.k. Send your address though and a new clean screw will be sent by return ( it will be a bigger one ) regarding the buzzer...is your alarm unit cylinder shaped or cube??andyb36 wrote:hi haydon
thanks
andy
al & chris
- Tribal Elder
Not checked anything yet apart from coolant level. looks like it could be earth or something as it did it again today but put indicator on to turn and it went straight off.helen&tony wrote:Hi
- haydn callow
Check the sensor screw is snug and the ring terminal is firmly in place.
haydn callow wrote:Check the sensor screw is snug and the ring terminal is firmly in place.
pm sent haydon
cheers
andy
- haydn callow
New screws on the way!!
