http://www.amazon.co.uk/Fastcar-150-Wat ... B00BPPGYMC
Not immense power 150 Watt and I would expect the speakers to take 10 Watts maximum. Just so we can play a few tunes at a festival without starting the engine and running the radio.
Now I wanted to know the easiest way to find out if the leisure battery is supplying the ciggy lighter or the starting battery. The obvious way would be plug something in and remove the leisure battery lead. (I am being lazy here!) Any quicker way to work that out.
There is a second ciggy lighter in the rear interior over the passenger side wheel arch as well.
If I find they are connected to the start battery I will just take a small 8Ah sealed small leisure battery
and cut the ciggy lighter plug off and put croc clips on so I will just take the small battery with us.
I prefer not to take the separate battery if poss and like the tidy ciggy plug already on it if possible.
cheers (Mr L. Bones)
