My poor old Bongo suffers from lack of use & recently I noticed the heater/cooling air only comes out of the dashboard vents. No matter where I set the mode button, it still exits through the dash vents. Not good in chilly wet weather! The mode display changes as it should & when you put it onto the windscreen setting it lights up & the fan goes to full speed but nothing is blowing onto the screen, again only the face vents.
Anyone any idea?
Mode button doesn't alter where the air comes out.
- Alacrity
- Tribal Elder
- haydn callow
Re: Mode button doesn't alter where the air comes out.
Are all the control rods connected on the White disk by your left foot ??
Good info, this is a common problem.
I knew that no good comes from change for change's sake!
So called improvements. Huh.
Frank
Frank
They flew, I took up naturism
- Alacrity
- Tribal Elder
Thanks, I will take a look sometime & report back.
