I think I agree (back Alright) is a bit of a clue really?helen&tony wrote:Hi
My guess is that it's a tracker!...looking at the wiring and connectors....
Project - Retrim and new paint
Moderator: Ian
Re: Project - Retrim and new paint
A Bongo is for life, not just for Christmas
				the.sasquatch
Was going to do the headlining in my freda, can i ask what kind of material did you use to cover yours? I guess it would have to be something with a fair bit of stretch to it?
Stretchy carpet that they use for lining vans http://www.ebay.co.uk/itm/321196452792? ... EBIDX%3AIT
I just sprayed glue over the original rear headlining and it worked (front one I coated in fibreglass resin - but this is not really required).
the.sasquatch wrote:Was going to do the headlining in my freda, can i ask what kind of material did you use to cover yours? I guess it would have to be something with a fair bit of stretch to it?
Sorry for the lack of photo's but I need to take some during the day and will do so this weekend (pics at night on my iphone are cr*p).
Below is a pic of what I'm working on at the moment
I need to grind a few bits off the Mazda frame to get the Alfa seat pads to fit and then I'll be covering all the foam to try and make it look good.
				the.sasquatch
Thanks for thatPuma931 wrote:Stretchy carpet that they use for lining vans http://www.ebay.co.uk/itm/321196452792? ... EBIDX%3AIT
After looking into a wrapping and then a respray I have opted to roller paint the van!
The link below has all the "How To" details and I'm going for RAL6011 light olive green with white AFT and some other white details.
I have ordered the paint £100 ish for 5ltrs of green and 2.5 of white. I decided on this option as it is cost effective, I can do it myself when it gets warmer (will do the doors, bumpers etc asap as I can unbolt and paint them inside), and you can achieve a good finish if you put the effort in.
http://forum.club8090.co.uk/viewtopic.php?f=38&t=18751
I quite like the idea of roller painting.  I once painted an old post office van from chucky yellow to bright blue using a roller  and  Tekaloid  paint which was then known as bus paint.  The beauty of it is that this paint applies quite thickly and can be machine buffed to correct the flaws.
If I had an older van with a bit rust, I would consider tackling the rust first then roller painting. Cheap and cheerful
Love the idea of rollering, and have been using tricks like that for years in other applicatons.  But I've no idea how I'd manage to do a neat green metallic paint as per the original colour, so not an option for me sadly when the time comes. Unless I decide to go for a plain colour scheme.  Hmmmmm.
You can't roller metallic
						mikeonb4c wrote:Love the idea of rollering, and have been using tricks like that for years in other applicatons. But I've no idea how I'd manage to do a neat green metallic paint as per the original colour, so not an option for me sadly when the time comes. Unless I decide to go for a plain colour scheme. Hmmmmm.
Yup, I'd pretty much worked that out, although never say never, as who'd have thought you might roller a car. I'm following your project with interest and good luck with it - great work so far.Puma931 wrote:You can't roller metallic
Very interesting - those T25 seem to suffer with rust on the seams quite a bit and the CombiColor and Vacar rust treatment  look to have done the job for no money.
Particularly interesting to me as I could quite happily slap that on with a brush to the underside of my Bongo and care not about the finish.
Great spot!
Great spot!
Thanks. Need to get some blinds made so that I can put the interior back together!
						mikeonb4c wrote:Yup, I'd pretty much worked that out, although never say never, as who'd have thought you might roller a car. I'm following your project with interest and good luck with it - great work so far.Puma931 wrote:You can't roller metallic
