Headlight bulbs going dim over time!
al & chris
- Tribal Elder
Just started using headlights more with darker nights and i thought they did not look as bright. A few years ago I put in 50% extra bright ones. Just been looking on web and it looks like bulbs do go dimmer over time. Has anyone else found this? Do different makes last longer.
Re: Headlight bulbs going dim over time!
I've kind of ducked this issue a bit by fitting 100w spotlights on my fender defender bar and linking them with a 3 way switch that allows them to work either with main beam only (which is how I always use them) or whenever side or main lights are on. I'll be interested to hear what people say about headlight bulbs dimming over time though as I've never changed mine.al & chris wrote:Just started using headlights more with darker nights and i thought they did not look as bright. A few years ago I put in 50% extra bright ones. Just been looking on web and it looks like bulbs do go dimmer over time. Has anyone else found this? Do different makes last longer.
They can dim and if they start getting dim they will continue to get dimmer!
Two possible problems, it might be the sockets for the bulbs, they have a habit of overheating and then giving a poor connection, replace them with ceramic ones from ebay if they get hot!
The bulbs themselves can build up a deposit of metal on the inside of the glass from the filament, this is meant to evaporate when they are next used - i.e. get hot - however sometimes the coating gets to thick and can't evaporate so the deposit gets thicker and the light gets dimmer - replace the bulbs.
- BongoBongo123
That sounds like the kind of lighting that you can feel when someone is overtaking. You can feel the projected warmth creeping up on you as it passes.mikeonb4c wrote:I've kind of ducked this issue a bit by fitting 100w spotlights on my fender defender bar and linking them with a 3 way switch that allows them to work either with main beam only (which is how I always use them) or whenever side or main lights are on. I'll be interested to hear what people say about headlight bulbs dimming over time though as I've never changed mine.al & chris wrote:Just started using headlights more with darker nights and i thought they did not look as bright. A few years ago I put in 50% extra bright ones. Just been looking on web and it looks like bulbs do go dimmer over time. Has anyone else found this? Do different makes last longer.
They call me light foot.
BongoBongo123 wrote:That sounds like the kind of lighting that you can feel when someone is overtaking. You can feel the projected warmth creeping up on you as it passes.mikeonb4c wrote:I've kind of ducked this issue a bit by fitting 100w spotlights on my fender defender bar and linking them with a 3 way switch that allows them to work either with main beam only (which is how I always use them) or whenever side or main lights are on. I'll be interested to hear what people say about headlight bulbs dimming over time though as I've never changed mine.al & chris wrote:Just started using headlights more with darker nights and i thought they did not look as bright. A few years ago I put in 50% extra bright ones. Just been looking on web and it looks like bulbs do go dimmer over time. Has anyone else found this? Do different makes last longer.
Think I'd start by giving the lenses a damn good clean.
- mikexgough
g8dhe wrote:They can dim and if they start getting dim they will continue to get dimmer!
yep..... I have seen this too when the battery/alternator is getting aged..... worth keeping an eye on....
philpdr wrote:Think I'd start by giving the lenses a damn good clean.
Ditto and check that the reflectors are still bright/shiny and not starting to tarnish (going black)
PS if you cant see in the light cant get out....
As I've got a 'thing' about excessive car borne lighting under urban street lighting conditions, I don't worry at all about the Bongo lights being dim (up to a point, anyway, and they get dangerously near that point if not cleaned!).
I see myself as an evangelist for the shortlived 'dim dip' era which was a much needed replacement for 'twinkle sometimes little star' sidelights and presented two adequate areas of visible, but not intense, illumination on oncoming vehicles. Regrettably, few other motorists understand the benefit of turning the wick down in towns and heavy traffic and being able to see better as a result.
The modern trend for multiple designer searchlights is way over the top anywhere other than for the sole vehicle on quiet unlit roads.
Frank
Frank
They flew, I took up naturism
I agree. Linking my powerful spots to main beam only and setting them to not point way down the road works very well in this respect as using main beam suggests you need to see where you are going as you are on unlit roads. And unless you are rally driving, you don't need to illuminate a great distance ahead (and it risks blinding oncoming cars if you don't dip promptly) but you do benefit from having curbs etc well lit. The rest of the time, the lighting is as much to be seen as to see the way forward. Modern cars driving with low set foglights on even with dipped headlights can be very distracting.Diplomat wrote:As I've got a 'thing' about excessive car borne lighting under urban street lighting conditions, I don't worry at all about the Bongo lights being dim (up to a point, anyway, and they get dangerously near that point if not cleaned!).
Frank
al & chris
- Tribal Elder
New ceramic connectors and new bulbs fitted. They are now a lot brighter, although the bulbs are brighter ones. Most of my driving is on unlight country roads and I just can't do without the brighter bulbs.g8dhe wrote:They can dim and if they start getting dim they will continue to get dimmer!
