Picture of glowplug relay position ?
Post by g8dhe » Sat Nov 15, 2014 2:46 pm
Does anybody have a good clear picture of the location of the glowplug relay position above the drivers side wheelarch they could put up or link to ?
dobby
Re: Picture of glowplug relay position ?
Post by dobby » Sat Nov 15, 2014 3:44 pm
Geoff, in front of main battery? If so I've sent a pic via Facebook usual image posting issues :roll:
Post by g8dhe » Sat Nov 15, 2014 5:59 pm
Thanks, but not the right relay, its mounted to the left of the battery actually above the wheel arch, and slightly behind the battery I believe - only having a V6 myself I can't confirm the precise location, but the relays down below the battery are common on all the variations, but many thanks for taking the effort, it really is appreciated!
dobby
Post by dobby » Sat Nov 15, 2014 7:08 pm
Ah, I've sent a few more over. They all look low rated though, also not to sure what I'm looking for.....
teenmal
Post by teenmal » Sun Nov 16, 2014 4:20 pm
Glow plug/heater relay is on the o/s inner wing behind the fuse box, you would need to remove the battery to gain workable access .
Posted a pic on the bongo forum for you.
Post by g8dhe » Sun Nov 16, 2014 11:23 pm
Thanks teenmal, hence why you don't normally see it, tucked right round the back there! Saved for the future, a lass on the FB pages was having problems, somebody had removed the fusible link leaving the connector behind, but she needs to examine the relay to see if they have stuck in a normal fuse or "whatever" in its place, but on further discussions there were several other electrical oddities, not mentioned at first that she needs to sort!
