How to test roof gas struts
Dodgey
Post by Dodgey » Fri Oct 31, 2014 12:11 am
My roof is getting slower and slower to go up. I've removed the motors and serviced them. They are fine
I'm wondering if my struts are tired but don't know how to test them - perhaps I just remove them and see how strong they are? What can I compare them against? One thing I do know is I removed struts from a VW pop top a while ago and they were amazingly hard to compress by hand.
roosmith
Re: How to test roof gas struts
Post by roosmith » Fri Oct 31, 2014 9:23 am
Have you checked voltage going to the motors? Mine requires a push, the motors are fine but I'm only getting just over 11v. I've checked the control box and fuse connections, all OK, so looking at cabling. Just never got round to it!
cmm303
Post by cmm303 » Mon Nov 03, 2014 5:20 pm
Dodgey wrote:My roof is getting slower and slower to go up. I've removed the motors and serviced them. They are fine
Struts are still under compression when roof fully up http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=67552
I can remember trying to check out my motor mountings as this was given as a possible cause of the roof not elevating properly. I could not budge them as was warned about damaging the fibreglass mounts. Should I have tried harder or is there a trick to it? My roof will now only lock out if I unzip the canvas and push.
Chris with BertieB
Tony x
Post by Tony x » Mon Nov 03, 2014 7:46 pm
I'm awaiting new struts from SGS.
When I get them, I said I'd add pictures of the mounting jig I'll be using.
I'll try and answer your question then Dodgey by using a set of stand on scales, compressing the old and then the new struts with one end on the scales and noting the weight reading when compressed by say 5mm so at least you have something to go on.
Dodgey
Post by Dodgey » Tue Nov 11, 2014 12:34 am
Perfect - let us know how you get on. I suspect if your struts need replacing the difference will be quite obvious between old and new.
Tony x
Post by Tony x » Tue Nov 11, 2014 11:09 pm
I'm still waiting for the struts Dodgey but I won't forget
Tony x
Post by Tony x » Mon Dec 01, 2014 10:34 am
Hello,
As an update Dodgey, it might be that I may not be able to answer your question as I don't yet know if I'm going to be able to source gas struts for the Bongo with the higher rising roof. If I can, then I will post an answer to your question.
