Cube Alarm Instructions
- Junior Bongonaut
Hi, just got a Bongo, its got a cube alarm with two temp alarms, voltage and fan control. My problem is that I can't find a manual anywhere to set it up. Can anyone help?
Re: Cube Alarm Instructions
not a manual/instructions but it may help.
http://lushprojects.com/bongopartsmk2/c ... mgno=.html.
I think that's a kitchen unit
I've got a Cube alarm although I'm not sure where I put the instructions. Pretty sure you press and hold the set button to adjust it.
haydn will have the instructions somewhere on his site. or give him a shout here.
http://www.coolantalarm.co.uk/shop/index.php
- haydn callow
Don't actually have any....just press buttons....it is quite intuitive.
- Junior Bongonaut
Had a play and think I've figured it out. However, Temp 2 is showing 'EH' when engine cold. Anyone know what this means? Is this a sensor issue?
- haydn callow
I think the 2 sensors have to be within 20degrees of each other or the fault code displays
