Which battery is which?
lizdigs
Post by lizdigs » Sat Oct 25, 2014 6:18 pm
Hello all,
I'm a newbie and yet to take my Bongo for its first outing.... popped out to the garage earlier and discovered the battery has gone flat. I have a charger but how do I know which is the starter battery and which is the leisure one? Please forgive my ignorance!!
Liz
teenmal
Re: Which battery is which?
Post by teenmal » Sat Oct 25, 2014 6:25 pm
Normally the Off Side (drivers side),if you connect the charger to that one it should be ok, but you Need to find out Why its Flat.
lizdigs
Post by lizdigs » Sat Oct 25, 2014 6:40 pm
Ah thank you - I was leaning towards the other one for some reason!
I have a feeling I left something on that shouldn't have been in the back but I'm not sure what!
wonkanoby
Post by wonkanoby » Sun Oct 26, 2014 6:32 am
starter on passenger side
Gasy
Post by Gasy » Sun Oct 26, 2014 8:04 am
If you have a leisure battery with split charge
And you left something on in the back it should not flatten your starter battery
Fridge or radio good starting places
Simon Jones
Post by Simon Jones » Sun Oct 26, 2014 10:24 am
wonkanoby wrote:starter on passenger side
Not unless it's left hand drive :)
Bear in mind if it's the twin starter battery setup, then you could have two flat batteries, but if you connect the charger to the one on the drivers side you can't go far wrong.
mikeWalsall
Post by mikeWalsall » Sun Oct 26, 2014 11:14 am
Ahhh ... the information arrows must have worn off yours ... this is mine with them still in place ..
Tip ... make sure the gutter drain is not gobbed up or water will spill over the electrics ...
lizdigs
Post by lizdigs » Sun Oct 26, 2014 5:46 pm
Thank you all - pleased to say after leaving the drivers side battery to charge overnight Barry started up perfectly this morning :D
Mike - I'm going to save your picture, you're right i think my helpful labels must have fallen off!!
briwy
Post by briwy » Sun Oct 26, 2014 7:36 pm
If you have a conversion with some sort of power control unit (like a Zig for example) you need to be careful with the switches as it's possible to have both the leisure and starter batteries used at the same time.
