K&N replacement for Mazda Bongo 2.0 flat panel filter?
- Purple Pixie
The 1999 Mazda Bongo/ Ford Freda 2.0 petrol paper air filter is 200mmx 236mm x 29mm according to the last one I bought
Now K&N do this reusable one http://www.knfilters.com/search/product ... od=33-2117
Part 33-2117 30 mm x 232 mm x 197 mm
Has anyone used one of these as an alternative to the disposable filter?
Close but no cigar?
Many thanks
Dr B
Close but no cigar?
Many thanks
Dr B
1999 Ford Freda - "Purple Pixie"
Re: K&N replacement for Mazda Bongo 2.0 flat panel filter?
Used one on my old landrover
Brilliant
Much more responsive to the accelerator
									Brilliant
						- Purple Pixie
specifically, does this particular one work as a replacement for the disposable paper one on the 2.0 petrol 1999?
- mikexgough
Here you go
Last column is the Part number from - http://www.gruppem.co.jp
SGL3 Diesel Turbo 95.05-05.12 2500 E-9280
SGLW Diesel Turbo 95.05-05.12 2500 E-9280
SGL5 4WD. Diesel 95.05-05.12) 2500 E-9280
SGLR 4WD. Diesel 95.05-05.12 2500 E-9280
SGEW 95.05-05.12 FE 2000 33-2117
SG5W 95.05-05.12 J5 2500 33-2117
SGE3 97.11-05.12 FE 2000 33-2117
- Purple Pixie
I've fitted one to my first diesel Bongo and then got one for my V6. Doesn't seem to perform any better than a conventional paper filter but does have the advantage of lasting forever. Probably over 3 or 4 years it will have paid for itself.
Perfectmikexgough wrote:Here you go
Copy and paste the filter part number into eBay and they pop up
There's always a 'bigger picture'
						- Purple Pixie
Easy to fit, just removed the air pipe from the filter housing to get better access,
and fitted like-for-like against the old paper one.
Acceleration seems smoother and maybe faster at the cost of a bit of induction roar.
Next thing is spark plugs and maybe (resistor cap?) HT leads
Dr B
Dr B
- mikeWalsall
Distributor cap (Dizzy cap) ..??
						- Purple Pixie
True! Will look to see if it has one!
- mikeWalsall
Easily sourced .. check how many ignition leads are on yours .. on the 2.0 there are usually only 4 .. (but there can be 6 or 7 on the V6) ..
http://www.ebay.co.uk/itm/BLUEPRINT-ADM ... 0732636592
						- Purple Pixie
Mazda Bongo 2.0 petrol dizzy cap ..... WAS flat panel filter
http://www.yoyopart.com/oem/4505923/bos ... nterchange one or two the same???
I'll move over to a new thread on dizzy cap equivalences!
- mikeWalsall
I would think that is the ... wrong ... dizzy cap for the 2.0 Bongo as that is for a five 'King Lead' ignition .. which yours does not have ..
						- Purple Pixie
Will look at the HT lead connectors later, maybe this is the one....?????
Cross Interchange for:BLUE PRINT ADM514212
Data Source: http://www.autopartoo.com/oem/blue-print/adm514212.html
More here: http://www.autopartoo.com/oem/partscros ... =ADM514212
- mikeWalsall
If Blueprint parts are available then (to me) that is by far the better ones to go for ..
Most Blueprint parts are genuine OEM (ie:- not pattern parts)..
They are usually made in the same Factories as .. Mazda .. Toyota ..Honda etc; source there own products from .. and generally cheaper than a franchised dealers price ..
