Auto gear box oil change - Extra BOLT!?!
TheStinkyHippy
Post by TheStinkyHippy » Sat Oct 04, 2014 12:03 pm
I'm having a WTF moment!
Changing the auto gear box oil..
Unbolted the sump.. saved all the bolts
Unbolted the filter.. saved the 4 boths
cleaned up.. found in the bottom of the sump a bolt... thought, opps must have dropped that.
But, the sump had 18 short bolts
the filter had 4 long bolts..
there is one medium bolt..
see picture
The bolt with the orange square is extra!
Have I lost my mind?
Looking underneath I cannot see any place it would go..
Please help!
wonkanoby
Re: Auto gear box oil change - Extra BOLT!?!
Post by wonkanoby » Sat Oct 04, 2014 1:33 pm
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=30096
sure its not from one of other bits under there
rita
Post by rita » Sat Oct 04, 2014 2:07 pm
Looks like it could be a Solenoid bolt/set screw, check the length and compare here.
http://lushprojects.com/bongopartsmk2/c ... 02.html#14
TheStinkyHippy
Post by TheStinkyHippy » Sat Oct 04, 2014 9:27 pm
I couldn't find any place for the extra bolt to go.
Put everything back together. It all seems to run fine.
Perhaps it was dropped in the factory or something as it was stuck to the magnet.
