Fitting a rear spoiler
Moderator: Ian
- Junior Bongonaut
Hi all,
I can see that there's a number of threads on this which I've read. It seems that fitting using a combination of measuring and masking tape imprints are the way to go.
HOWEVER,
I seem to have to bits (one on each side) that stick out of the spoiler and look as though they should clip into the body of the van
http://s1372.photobucket.com/user/Bunke ... 8.jpg.html
There's no spoiler on my van currently so should I cut these off? Drill an additional hole on each side for these (3 total on each side)? Or are there any other suggestions?
Ps may be asking a few questions about wiring in the brake light after I've got past this......
HOWEVER,
Re: Fitting a rear spoiler
yes they are the locating pins for correct allignment when factory fitted, i fitted mine , this is the position the two bolts need to be
prior owner of >>>>1999 2.5 diesel ex tin top &FORD FREDA 2000 2.0 LTR PETROL
- Junior Bongonaut
Thanks Colin, I'll saw them both off. Thought that would be the way but thought I'd double check!
file a couple of bolts to a point and screw them into the threaded holes in the spoiler offer it up to van and once in the correct possition wiggle it about very slightly so it makes a mark on the van better if some one helps to hold one end hope this helps
- Junior Bongonaut
So,
Drilled out the plastic guidance pins, marked the holes, drilled and with a bit of faffing hey presto.
Not perfect but I think it passes the eye test......
http://s1372.photobucket.com/user/Bunke ... g.html?o=1
I did however sidestep wiring in the brake light for the moment. Task for another day!
Looking nice
I do prefer them with a rear spoiler
Think that brake light will have to be working before next mot tho
Not if it's not there Just remember to tie a piece of cotton to the cable as you pull it through so that you refit it easily.
Looks good by the way
There's always a 'bigger picture'
Actually, I don't think it's tested for the MoT.
On my MX5 (import), I have the boot mounted brake light configured as a rear fog light. This was done after consulting the MoT man three MoTs ago
Can anyone tell me what size thread the bolts are please?
As I recall, they are M6 x 1.0 which is widely available at any hardware/DIY/tool store.
Cheers Simon
