Motorised wing mirror problem
bongojoe
Post by bongojoe » Wed Aug 13, 2014 10:10 pm
One of our neighbours, thinking they were doing us a favour, 'flipped' the driver's side wing mirror in by hand.
The missus 'flipped' it back manually and now the motorised retraction doesn't move that mirror.
I haven't had a good look myself yet, but is it likely a goner or are the designed to cope with being manually retracted?
1999 2WD 2.5L Diesel AFT
Re: Motorised wing mirror problem
Post by g8dhe » Wed Aug 13, 2014 10:12 pm
They are designed to be manipulated as well, just run the mirror out as normal and you should hear a clicking at the end, then retract and it should be OK, unless the ratchet bit has broken.... :-(
