reich tap problem
Moderator: Doone
janeatnumber48
reich tap problem
Post by janeatnumber48 » Wed Aug 06, 2014 4:53 pm
We had to replace our Reich single microswitch tap. Managed to buy an exact replica in a shop.
Wired it all up thinking this is going splendidly, however the white platic tube that connects the water hose to the actual tap bottom that goes into the pipe doesn't sit in with a tight fit, even though we have tried to tighten up using a jubilee clip. So when you turn on the tap, the bottom connector comes loose from the hose and you get a shower you weren't planning on taking.
Pretty sure we didn't have any bits missing.
Any ideas on how to fix this problem or how to get round it?
Don't know how to post a picture on here, but have taken one i can send if anyone needs to see what i'm on about.
Jane at48
Simon Jones
Re: reich tap problem
Post by Simon Jones » Wed Aug 06, 2014 5:05 pm
Sounds like its not quite the same model or there's something missing. Ofter the pipes harden with age so don't make a good seal once disturbed. May be worth chopping off a little bit to get back to the 'fresh' section or maybe even replacing that whole section of pipe. Info on how to upload photos: http://www.igmaynard.co.uk/bongo/forum/ ... =42&t=9285
Post by francophile1947 » Wed Aug 06, 2014 5:21 pm
janeatnumber48 wrote: Don't know how to post a picture on here, but have taken one i can send if anyone needs to see what i'm on about.
Jane at48
Simple - see Guidance Section here http://www.igmaynard.co.uk/bongo/forum/ ... =42&t=9285
