Bongo friendly garage Purbeck area
Moderator: westonwarrior
Snoozie
Post by Snoozie » Thu Jul 31, 2014 2:46 pm
Hi, does anyone know of a Bongo friendly garage or mobile mechanic near the Purbeck area of Dorset? - Wareham/Swanage
Poole is not too far and I know of RD Motors, Hamworthy (near Imperial Cars). So far I have only used them to check over the Bongo when I bought it and they seemed helpful and friendly. They are Bongo specialists, but I don't know if they are very expensive or not. Has anyone else had experience of them? I understand that you may not be able to comment on here if your experience was negative, but in that case perhaps you can pm me.
I read on here somewhere that there is a mobile mechanic in Corfe Mullen, but I may be too far away for him unless I can take the Bongo to him.
For the last 2 years I have been using a garage called Rentech in Holton Heath Industrial Estate for MOT and servicing. Renault specialists but they seem very good, and excellent value MOT (<£40). I think they do a lot of vans, being on an Industrial Estate, but whether that has any bearing on being good with Bongos - I have no idea.
Reading about the Bongo coolant system on here, draining etc. makes me wonder if I should go to a Bongo specialist. :?: Either that, or I'll have to find a tactful way of asking Rentech if they have experience of this. I can hardly suggest they watch a You Tube video - don't want to offend them!! :oops: Being female I tend to worry about being ripped off although I can manage to sound a bit technical if I have an inkling of what a problem might be :D
Keep Calm and Bongo On!
Re: Bongo friendly garage Purbeck area
Post by Bob » Thu Jul 31, 2014 10:26 pm
There's a good few owners your way, someone will know a good garage. :)
Snoozie
Post by Snoozie » Thu Sep 25, 2014 11:04 pm
Bob wrote:There's a good few owners your way, someone will know a good garage. :)
Hoping one of them will post one day !!
Post by Bob » Thu Sep 25, 2014 11:27 pm
Let's hope so. [-o<
Post by mikeonb4c » Fri Sep 26, 2014 9:32 am
I don't think a decent garage should take offence about being advised of the strict procedure to follow with bleeding a Bongo. And any decent garage ought to be able to bleed one properly if they follow the rules and the Bongo has no issues. I think it's a little more straightforward if they don't drain the rear heater as that is a likely area for trapped air if it is drained. I've done 3 coolant changes like that with no issues, and it still means almost all the antifreeze gets replaced.
Fond memories of Purbeck. My mum had an old cottage at Acton, Langton Matravers where I spent many happy times flying model gliders on the coast and on the hills.
Mark.T
Post by Mark.T » Fri Sep 26, 2014 12:03 pm
Am I right in saying that the 'only' odd thing about the Bongo as far as general servicing is concerned is that care needs to be taken to properly bleed the cooling system?
We've not had ours long, so I haven't had to take it anywhere yet.
There's always a 'bigger picture'
Post by mikeonb4c » Fri Sep 26, 2014 2:53 pm
Mark.T wrote:Am I right in saying that the 'only' odd thing about the Bongo as far as general servicing is concerned is that care needs to be taken to properly bleed the cooling system?
I reckon that's about right but, like any car, but especially an uncommon one, a garage familiar with a Bongo will be slicker at getting the job done and in diagnosing faults, so may offer better rates.
Mark.T
Post by Mark.T » Fri Sep 26, 2014 7:51 pm
Indeed, thanks.
Parhelion
Post by Parhelion » Tue Jun 28, 2016 9:31 pm
Hi, I'm in Dorset, Purbeck area too. Any recommends now please? Don't need anything doing yet but will need service autumn/winter time? Many thanks,
Post by Bob » Tue Jun 28, 2016 10:07 pm
It bubbled up, Imperial in Poole:
http://www.imperialcar.co.uk/
cmm303
Post by cmm303 » Wed Jun 29, 2016 8:21 am
absolutely agree with both quotes. There isn't a golden rule. Some bongo specialist charge rates exploiting the niche market. Taking into account distances and time, sometimes the independent on your doorstep that you trust may be comparable even if they want to allow more time to do a particular job. However nothing beats the specialist for diagnosing peculiar faults.
Chris with BertieB
Parhelion
Post by Parhelion » Wed Jun 29, 2016 9:10 pm
Thanks again!
Return to “South Wessex”
