Automatic shift problems V6 - HELP!!
andrewjames
Post by andrewjames » Sun Jul 27, 2014 4:58 pm
Hi, we're new to Bongo Fury having bought the van at the end of last year. We're having problems with the automatic shift. It goes through 1,2,3 but refuses to go into top gear more often than not, and if it does it's only a matter of time before it drops out. It doesn't happen all the time, for example we went away for the weekend on Friday and it was fine all the way there, we thought it had been fixed as we had just collected it from the garage. However, it was short lived, and on the way home it dropped to 3rd then went back up quickly. A mile or so later it dropped down again and didn't go back up at all. It results in us driving at 50mph on the motorway and being overtaken by HGV's. We have noticed that when it's working perfectly the gear changes are smooth and almost unnoticeable, but when we start having issues with top gear ie not going into top gear at all or dropping into 3rd, the other gears then become clunky. We have taken it in twice to be fixed they have changed a sensor (not sure which) and the latest one was a wiring/electrical problem, we have also put fresh gearbox oil in. We're tearing our hair out with frustration and would welcome someone solving this puzzle for us.
Re: Automatic shift problems, HELP!!
Post by mikeonb4c » Sun Jul 27, 2014 6:41 pm
Where are you based. Hopefully a local Bongo expert can help. It doesn't sound terminal. Sensor connections, TPS and gearbox solenoid packs are things I've heard mentioned before as causes of trouble (search old threads) but someone in the know would be useful. Good luck and keep us posted.
Post by francophile1947 » Sun Jul 27, 2014 6:45 pm
Welcome to the madhouse 8)
Sorry, I've no idea what your problem is, but there'll be responses soon enough :D
Put your location in your profile - it really helps us to help you 8)
andrewjames
Post by andrewjames » Sun Jul 27, 2014 7:32 pm
I've added my location, thanks for the tip. If you know of any Bongo experts in my area please let me have their details, I've made enquiries but been unsuccessful.
Post by Northern Bongolow » Sun Jul 27, 2014 9:44 pm
when did you last change the fuel filter.
Post by Bob » Sun Jul 27, 2014 9:48 pm
Wheelquick in Wigan are the guys, but go with what Ady said.
philpdr
Post by philpdr » Sun Jul 27, 2014 11:52 pm
Japan Direct in Bury(Tel 0161 763 3003)are the closest "specialists" to our area,very good reviews from members on here.If you type their name into the search facility you can read some comments.
rita
Post by rita » Mon Jul 28, 2014 9:05 am
What engine does the vehicle have, does the Hold light come on at any particular time without pressing the hold button on the gear stick.
andrewjames
Post by andrewjames » Mon Jul 28, 2014 9:42 am
It's a 2.5 v6 petrol. No, HOLD doesn't appear on the display by itself.
