Tested the fault codes and got 7 (Vehicle speed sensor) and 12 (Throttle position sensor)
Having previously messed with the TPS I backed it off a bit, soldered my twisted wires together, and hoped for the best.
Now it still trips at the same point - when lockup is engaged but I get fault code 1 (Engine speed sensor)?
Apart from not having the hold function it drives fine, goes into 4th and locks up the tourque converter ok
Any ideas what to try next - I could dismantle the whole speedo arrrangment again and clean all the contacts?
Wondering if when you fit one of these box/chips there are any othe wires uct that I missed - strangely there was an earth wire (green/yellow) that had previously been cut and resoldered, maybe this used to connect to somwhere and was cut when the box/chip was installed
Unfortunatley I cant find a website for Import solutions who made the box/chip to look for the fittng instructions.
p.s. yes I have read ALL the threads about flashing hold lamp and the associated fax sheets
