top and bottom Temperature sensors
Has any one got or can obtain Temperature = voltage (or/and Ohms) for either of these two sensors? Does anyone know the thread sizes? Strange request I know but I am doing a project. Thanks if you can help.
Re: top and bottom Temperature sensors
Can you explain in Dobber terms what you are actually referring too.
Top and bottom coolant temperature sensors. The ones that are located on a 2.5 TD Bongo engine. I am not familiar with your request for "Dobber Terms"! However if you do not recognise my request and its meaning there is no further explanation that I can give you.
Ah a project..
The ECT sensor on the side of the engine and the temperature sensor on the top front of the cylinder head.
The thread will probably be 1/8 BSPT or GAS.
If you look up Intermotor 52551 and 55123 you will probably get the values.
Ok Spill, what's the project.
