WHY DOES THE FAN START WHEN IGNITION IS ON
Jonny Tunnel
Post by Jonny Tunnel » Wed Jun 11, 2014 10:57 pm
Not sure whats up, but Bongo fan goes on when i put ignition on, without even starting the engine. Engine is cold, hasnt been used today.
Its a mystery ready to be solved..
cheers Jonny
Driver+Passengers
Re: WHY DOES THE FAN START WHEN IGNITION IS ON
Post by Driver+Passengers » Wed Jun 11, 2014 11:08 pm
Jonny Tunnel wrote:Not sure whats up, but Bongo fan goes on when i put ignition on, without even starting the engine. Engine is cold, hasnt been used today.
cheers Jonny
Which fan?
Radiator fan(s) or the scavenger fan just in front of the engine?
The sensor connections to check, respectively, are:
- temperature sensor low down towards the rear of the engine block on the driver's side
- sensor just behind the handbrake, poking down into the engine bay
Both sensors feed the ECU, which controls the fans.
Image Image
Jonny Tunnel
Post by Jonny Tunnel » Wed Jun 11, 2014 11:13 pm
Ok thanks, what should i be checking for?
Driver+Passengers
Post by Driver+Passengers » Thu Jun 12, 2014 12:09 am
First off, which fan... then first checks are free - are the connectors attached, corroded? Otherwise, checking the wires, testing the sensors themselves...?
Image Image
Simon Jones
Post by Simon Jones » Thu Jun 12, 2014 12:41 am
Rad fans will also come on when A/C is engaged.
Driver+Passengers
Post by Driver+Passengers » Thu Jun 12, 2014 1:13 am
I removed "are the blowers on" from my original post thinking myself rude, but if A/C was also on...
Image Image
Simon Jones
Post by Simon Jones » Thu Jun 12, 2014 8:06 am
In theory, A/C compressor will only engage when engine running, so it ought not to be that. My guess would be the engine bay sensor is open circuit resulting in the scavenger being on, but its not clear from the OP which fan is being referred to.
Jonny Tunnel
Post by Jonny Tunnel » Thu Jun 12, 2014 3:10 pm
Im sorry i dont know what the scavenger fan is.
A/C is defo off
Simon Jones
Post by Simon Jones » Thu Jun 12, 2014 3:19 pm
Big one in front of the engine (roughly where the gear lever is). Then there are two more traditional fans behind the radiator.
Jonny Tunnel
Post by Jonny Tunnel » Thu Jun 12, 2014 7:36 pm
i can hear it quite clearly so im guessing its the scavenger fan
Driver+Passengers
Post by Driver+Passengers » Thu Jun 12, 2014 7:49 pm
If you lift up the driver or passenger's seat - you can see the scavenger fan, just in front of the engine - angled slightly up the way. The radiator fans are bolted onto the back of the radiator, and harder to see (though you can feel the air with the seats up).
Image Image
Jonny Tunnel
Post by Jonny Tunnel » Thu Jun 12, 2014 9:41 pm
Nice one D&P, ta
