Under Cabinet Lighting
Moderator: Ian
- Tribal Elder
I knew when we put in our overhead cabinets that I wanted some kind of slimline lighting that was low current, so the obvious choice was the self adhesive LED stuff (colour changing stuff in this instance) that's widely available. However I didn't like the fact that it looks a little 'unfinished' when simply stuck to the underside of a unit.
Much searching revealed a nice, black anodised extrusion that screws to the surface in question. You then simply stick your LED tape into the extrusion & click on the diffuser strip. http://www.ebay.co.uk/itm/281151575915? ... 1439.l2649
I'm very happy with the results, the lights need wiring in yet to the remote controlled RGB controller, that's a job for the weekend.
- Bongonaut
Re: Under Cabinet Lighting
Nice find! I've been looking for something exactly like this. I tried hiding my led strip behind a small aluminium extrusion but it cut out too much light. This will be perfect.
Now that I like!Just ordered a couple of lengths,excellent find.
Very smart. Have you got any photos showing them in use?
- Tribal Elder
Hopefully will have this weekend, in the process of sorting the wiring, but since I'm a bit anal everything takes three times as long as it should to get right.Simon Jones wrote:Very smart. Have you got any photos showing them in use?
Very neat. Is there enough space in the strip to lose some thin lighting wiring as well?
Chris with BertieB
- Tribal Elder
- Tribal Elder
Hopefully todqy I'll get them wired in.
Excellent find. Who's todqy?
Wet day for it
Wet day for it
- Tribal Elder
Sunny here in Bristol.mikeonb4c wrote: Wet day for it
It's complete. I'll wait umtil it's dark & get some pics.
Are these strips for 12volts or 240?
- Tribal Elder
- Tribal Elder
