Waxoil or Underseal?
donaldthomps
Post by donaldthomps » Thu May 22, 2014 10:23 pm
Hi - we have just purchased a fresh import Bongo.
What's the most effective way of sealing the underside - Waxoil or Underseal?
Thanks in advance.
Simon Jones
Re: Waxoil or Underseal?
Post by Simon Jones » Thu May 22, 2014 11:28 pm
There's a handy factsheet here: http://www.igmaynard.co.uk/bongo/member ... ealing.pdf
I think most of us go for Waxoyl but it will need to be re-applied every few years.
mikexgough
Post by mikexgough » Fri May 23, 2014 5:56 am
Whatever treatment you use..... don't forget the inner rear wings(and dose them well - (I have loaded mine 5 times after my arches were replaced..before putting the trim back on)... you will need to remove the rear trim panels with a panel tool and they panels are kept in place with metal spring clips.... the reason for this advice....you only have to see how many Bongo's which have been here for 5 years + that are now having rear arches replaced (mine included), because when they were waxoyled etc they missed the inner arches ...
My Bongo gets an inspection/Top up spray every year...
donaldthomps
Post by donaldthomps » Fri May 23, 2014 7:11 am
Thanks, very good advise.
I live near Mansfield / notts, can anyone recommend a garage who can do this in my area?
Driver+Passengers
Post by Driver+Passengers » Fri May 23, 2014 10:16 am
A couple of hours from you - Chassis Clean in Cheshire has been mentioned a few times as doing a good job - several Bongos have been there.
http://www.chassisclean.co.uk/
Image Image
weebrian
Post by weebrian » Fri May 23, 2014 10:50 am
I waxoiled my Bongo when it was imported and though I say it myself, I think I did a reasonable job. Never again! Dirtiest job I've ever done with a spray gun.
My van was converted on import so I have never been able to access the rear arches from the inside. Just wondered if there was an easy way to get in from outside to complete the treatment.
Sorry to hijack the thread.
Brian
Simon Jones
Post by Simon Jones » Fri May 23, 2014 11:47 am
Several options:
- Remove bumper & go in via the vent holes at the rear of the arches. You should do this anyway as they rot around there anyway.
- Remove the rear light clusters and use a suitable lance to get as far round as possible.
- Remove the plastic plugs in the wheelarch & inject inside
None of the above will give great coverage so the best solution would be to try to remove / work around the conversion. It's only going to be screwed in place :)
weebrian
Post by weebrian » Fri May 23, 2014 1:48 pm
Thanks for the tips Simon.
briwy
Post by briwy » Fri May 23, 2014 9:27 pm
Driver+Passengers wrote:A couple of hours from you - Chassis Clean in Cheshire has been mentioned a few times as doing a good job - several Bongos have been there.
We had our fresh import done there, first class job.
It takes a couple of days as they pressure wash it, and then put it overnight in a drying chamber, relevant bits are masked up underneath and trim removed where necessary.
Wouldn't hesitate to use them again, not cheap (around £350) but worth it on a fresh van.
Diplomat
Post by Diplomat » Fri May 23, 2014 9:56 pm
donaldthomps wrote:Hi - we have just purchased a fresh import Bongo.
Thanks in advance.
Simplest way is to have a leaky diesel pump. The entire underside (rearwards of the engine, at least) gets coated with a fine water repellent spray. So does the back window, unfortunately.
Frank
They flew, I took up naturism
nicstrike
Post by nicstrike » Sun May 25, 2014 12:29 pm
you can get underseal with waxoyl in it. it stays a little tacky but is great stuff. if you have access to a compressor and schults gun , you can mix your own too. if just applying waxoyl , I normally add a drop of white spirit or (carefully) warm on a stove to thin it down and then run it through a paraffin gun. gives a lovely coating and with the long nose on the gun you can get into all the awkward corners.
