Fiamma back box
Dr Fingers
Fiamma back box
Post by Dr Fingers » Thu May 08, 2014 6:13 pm
Thinking of getting the Fiamma 360 rear storage box, but unclear as to the cheapest option for mounting it. We don't need bikes, so open to suggestions.. :)
Can anyone tell me if the box obscures the rear number plate/lights etc?
Thanks all.
Derek
Dr Fingers
Re: Fiamma back box
Post by Dr Fingers » Tue May 13, 2014 12:23 pm
Going for 320 (smaller) but question remains re how to mount? Will it obscure number plate?? 320 won't cover rear lights, so no problem there.
Anyone?
Derek
helen&tony
Re: Fiamma back box
Post by helen&tony » Tue May 13, 2014 3:13 pm
Hi Derek...
Have you thought of a small trailer...a Daxara or Erde ?...you can get them with a lockable lid!
Dr Fingers
Re: Fiamma back box
Post by Dr Fingers » Tue May 13, 2014 3:17 pm
Nah, I hate towing :( :(
Derek
helen&tony
Re: Fiamma back box
Post by helen&tony » Tue May 13, 2014 4:32 pm
Hi Derek...
Seriously, with one of those little tiddlers on the back, it's not even visible, let alone "feeling it"....weight wise it's like a pimple on a pound of pickled pork!.....and they REALLY are useful!
gilly99
Re: Fiamma back box
Post by gilly99 » Tue May 13, 2014 8:53 pm
For well under the price of a thule or fiamma box, you could get a bak-rak + large plastic box...far more flexible and then able to use the full weight limit - just need a towball!!
http://s1255.photobucket.com/albums/hh6 ... ack%20Box/
Sorry can't find a better picture, but from memory the box was only £40 and still going strong 2-3 years later. With a few brackets you can adapt the bak-rak to lots of other uses and its 2mins to remove via quick release clamshell.
vanvliet
Re: Fiamma back box
Post by vanvliet » Wed May 21, 2014 11:53 pm
I had one of the smaller fiamma boxes but it was too small to be of much use.
The 360 (147cm wide x 38cm deep x 68cm high ) is def the way to go if you opt for a Fiamma .It is the right width for the rear of the Bongo, looks good, and is deep enough to usefully cart reasonably sized bits and pieces (including a porta 335!)
The other sizes are either too narrow , too deep or too bl---y massive IMO.
The box mounts to a Fiamma bike rack in a few minutes using quick detach fittings
If you get a s/h one check it very carefully for hairline cracks, check the piston operation and remember to ask for the lock keys and QD fittings
Origo bio stove - no Bongo!
Dr Fingers
Re: Fiamma back box
Post by Dr Fingers » Thu May 22, 2014 9:47 am
Got a s/h 320 seems big enough, but half the fittings were missing, so £48 for a new set! Seems solid though, no cracks and closes well.
On the hunt for a VWT4 carry bike now..
Derek
vanvliet
Re: Fiamma back box
Post by vanvliet » Thu May 22, 2014 5:42 pm
Fiamma used to do a '300' model ( the original one I had which was too small) It was 38 cm deep and the same width as the 320. I think that the 320 and 500 protrude too far towards the rear and look bulky - both are 53cm deep.
The 320 is only 38cm deep but is the full width of the Bongo, has good weight distribution ,and looks much better.
' The Backrack' protrudes further back than all of the Fiammas!
Of course it is all down to personal preference and experience
Dr Fingers
Re: Fiamma back box
Post by Dr Fingers » Thu May 22, 2014 7:12 pm
You may be proven right..the 360 is full width, after all..
Just received the factory fixing kit..lots of bits, no instructions :shock: :shock:
May upgrade in future.
Derek
vanvliet
Re: Fiamma back box
Post by vanvliet » Thu May 22, 2014 9:38 pm
Sorry, it should have read that the 360 is full width of the Bongo and is 38cm deep,not the 320
vanvliet
Re: Fiamma back box
Post by vanvliet » Fri May 23, 2014 7:18 pm
Just noticed that the s/h T4 rack on Ebay went for £185 - crumbs!
Dr Fingers
Re: Fiamma back box
Post by Dr Fingers » Fri May 23, 2014 7:35 pm
Very bizarre..just bought a new one for £199....inc postage!
Derek
vanvliet
Re: Fiamma back box
Post by vanvliet » Fri May 23, 2014 9:08 pm
The standard one comes with two rails. Add another rail and associated fittings for £50-£70 each. Can't remember how many rails the Ebay one had but it seemed to go for a high price
