Which fuses to put on leisure battery
Hi all
I'm away in the lakes for the weekend
And had planned to change some elec items over to my second battery
But left my other iPad with all me bongo downloads on at home
Can someone pls confirm which fuses do which or better still a fuse board layout diagram pls
I want to change the radio and the cigar lighter socket in back over to me second battery
Which fuses are these?
I'm going to wire through the front of fusebox removing fuse and pushing in spade connector from me second battery
Can some one pls confirm this goes in the bottom half of fuse holder
Many thanks
Gasy
Many thanks
Gasy
Re: Which fuses to put on leisure battery
There's a factsheet about the fusebox here http://www.igmaynard.co.uk/bongo/member ... usebox.pdf - I've no idea where the wires go, as I followed Pippin's instructions and cut the wires behind the fusebox.
I'm not a paid up member
Will have a play tomorrow
I know I can sort it sure it's fuse 1 & 8
And bottom of fuse holder
We will see
Thanks anyway
We will see
Thanks anyway
have you tried a search on google for bongo fusebox diagram, and then look on the Images tab, I did have a copy printed out that I kept in the van but cant for the life of me find it. If i could I would have taken a photo and sent it too you.
									That'll Be The Day.........
'99 Silver V6 Moonfleet Conversion
Cheers mate
Yep did google
Annoying cause I have all infi on works iPad
Just didn't bring it this weekend
No prob
									Yep did google
No prob
just had a look through the service manuals and the info aint there either sorry friend.
- daveblueozzie
Use the same fuse rating from the fuses you take out when you rewire and it is normally at the bottom of the fuse you put the new wires.
									Lost without my Bongo.
Gasy wrote:Hi all
Many thanks
Gasy
1. Cabin 10A
2. Hazard Lights 10A
3. Brake Lights 15A
4. Central Locking 30A
5. Horn 10A
6. Blinds O/S 15A (if fitted)
7. Blinds N/S 15A (if fitted)
8. 12v Power outlet, Radio & Electric Mirrors 15A (if fitted)
9. Engine Management System 15A
10. Dashboard 15A
11. Indicators 10A
12. AFT Roof 30A or Electric Sunroof (dayvan) 20A
13. Rear Wipers and Washers 20A
14. Electric Windows 30A
15. Front Wipers and Washers 20A
16. Aircon 10A
17. Sliding Door 15A
18. Glow Plugs 10A
19. Blank
20. Blank
21. Additional Equipment 30A
22. Rear Heated Window 30A
Cool thankyou
