Electric hook up in France
Moderator: Muzorewa
g4gxl
Post by g4gxl » Thu Jul 18, 2013 11:37 pm
In the UK we have been using one of these since we got our Bongo 2 years ago -
We are going to France soon and it will be the first time I will have used electric hook-ups abroad.
I seem to remember reading that I may need an adapter.
Possibly two adapters - one for a different plug and another in case of reversed polarity ?
I can't find any reference now - did I dream it, is the cable and plug in the photo fine for France or do I need to look for an adapter ?
1996 4wd AFT 2.5l diesel, white over silver with Chargespeed body kit (and furry dice)
Re: Electric hook up in France
Post by Muzorewa » Fri Jul 19, 2013 4:36 am
Possibly this one.... http://www.igmaynard.co.uk/bongo/forum/ ... 38&t=51150
Note that you'll probably have a normal blue socket but you could have a European domestic socket :wink:
Post by Muzorewa » Fri Jul 19, 2013 6:18 am
Velocette
Post by Velocette » Sat Jul 20, 2013 11:49 pm
If you are quick with a screw driver it might be worth just buying a French earthed domestic plug from Leclerc and replacing the commando plug with it as needed. I guess it would be a pain if you were doing short stops.
I have camped at about 6 sites in France using one of those hook-ups and only found one with reverse polarity. I believed they started standardising the polarity in 2002 so the problem may be diminishing.
I found that the neon on the hook up didn't light when i was at the reverse polarity site. You do find the domestic sockets quite often. Worth buying a polarity tester to be sure, I got one from B and Q, martindale type, detects other faults too.
Simon Jones
Post by Simon Jones » Sun Jul 21, 2013 12:39 am
You can buy a continental adapter lead for under fiver which is less hassle than changing plugs over:
http://www.amazon.co.uk/dp/B0029OIVQU
You can get complete set of everything you could possibly need for £25, but you could easily make it for less than that:
http://www.ebay.co.uk/itm/EU-Europe-Con ... 3a8102206d
You can pick up 16A plugs and sockets for about £3 each and 1 metre of 3 core 13A outdoor mains cable can be purchased from Maplins or a decent hardware store.
g4gxl
Post by g4gxl » Mon Jul 22, 2013 12:36 pm
Thanks for the replies.
I ordered an adapter off Amazon to be on the safe side - and a mains tester
We are staying at some large modern sites so there shouldn't be an issue.
vj3
Post by vj3 » Sun Apr 13, 2014 7:03 pm
I have a continental adapter, but have never needed it. camped in germany, france austria and italy.
all had a regular hook up connection
v
scanner
Post by scanner » Sun Apr 13, 2014 8:07 pm
vj3 wrote:I have a continental adapter, but have never needed it. camped in germany, france austria and italy.
v
You have been lucky my rate is 50/50. The most recent to use a standard domestic connector was a brand new site at Marck near Calais.
So don't bank on it.
ramrider
Post by ramrider » Wed Apr 30, 2014 10:18 am
g4gxl wrote:In the UK we have been using one of these since we got our Bongo 2 years ago -
Can you still buy these, they look like a good idea
Post by Muzorewa » Wed Apr 30, 2014 10:24 am
Yup - http://www.towsure.com/product/Camping_ ... t_3_Outlet
You should still take an adaptor and something to check and reverse reversed polarity :wink:
Read and inwardly digest the contents of this thread http://www.igmaynard.co.uk/bongo/forum/ ... 38&t=51150 :idea:
mikexgough
Post by mikexgough » Wed Apr 30, 2014 8:00 pm
Muzorewa wrote:Yup - http://www.towsure.com/product/Camping_ ... t_3_Outlet
Spot on..... I have a standard adapter and reverse polarity one..... whatever.... use a tester plug when hooked up and change if reverse polarity.... simple... Just make sure you mark the reversed adapter...
