I found a replacement LED tube for the florescent rear one.
Moderator: Ian
somaRich
Post by somaRich » Thu Apr 03, 2014 11:26 am
I needed a replacement florescent tube for my rear cabin, so did a bit of digging and found this
http://www.amazon.co.uk/gp/product/B00C ... UTF8&psc=1
I haven't seen it at night but its definitely brighter than the old florescent tube and should use about 90% less power.
dave_aber
Re: I found a replacement LED tube for the florescent rear o
Post by dave_aber » Thu Apr 03, 2014 11:42 am
Looks like a good idea, ordered one to see how good!
Image...Image
Dr Fingers
Post by Dr Fingers » Thu Apr 03, 2014 11:42 am
Thanks for this! Just what's needed.
Derek
Mickymouse
Post by Mickymouse » Thu Apr 03, 2014 12:21 pm
It says this is for 240 volts, is this OK?
White 1996 P.reg SGL3 2.5D AFT Side Conversion
scanner
Post by scanner » Thu Apr 03, 2014 12:45 pm
Mickymouse wrote:It says this is for 240 volts, is this OK?
All flourescent tubes are, the gubbins in the bulb holder is a small inverter.
Judging by this they work OK in Bongos.
http://www.amazon.co.uk/product-reviews ... ewpoints=1
somaRich
Post by somaRich » Thu Apr 03, 2014 12:54 pm
Scanner that's my review...
scanner
Post by scanner » Thu Apr 03, 2014 1:41 pm
somaRich wrote:Scanner that's my review...
I guessed that, :wink: but it answered the question didn't it?
Dr Fingers
Post by Dr Fingers » Thu Apr 03, 2014 2:08 pm
Well, ordered, so let's hope it's a go-er..
Derek
mikexgough
Post by mikexgough » Thu Apr 03, 2014 4:26 pm
Thats the one I pointed out in the other thread a few weeks ago.... glad it works... one on order for mine....
somaRich
Post by somaRich » Thu Apr 03, 2014 5:25 pm
I'll take some night shots this weekend so you can see how bright it is (or not!).
2newbies
Post by 2newbies » Thu Apr 03, 2014 6:42 pm
Hi, thanks for that....just ordered one too...
peanutcrusher
Post by peanutcrusher » Thu Apr 03, 2014 9:49 pm
LOL at least there is an answer now, but did you get it from the UK or china.
I modded mine very happy with.
Bongo now work later !!! :) :)
Post by mikeonb4c » Fri Apr 04, 2014 7:52 am
Just to be clear, has anyone now fitted theirs and tried it at night and, if so is it brighter and is the light harsher or softer than the standard fluorescent tube. Great find, by the way =D>
somaRich
Post by somaRich » Fri Apr 04, 2014 11:01 am
Fitted mine and took some shots but I didn't have anything to compare them to as i had no shot of the old tube.
Its definitely brighter than my old tube and just about enough to read by,
Its a very blue light and not as warm as the old tube.
Its not great, I would prefer some brighter LED's and will keep an eye out for an improved version.
Mine came from the UK in a few days.
Post by mikeonb4c » Fri Apr 04, 2014 6:33 pm
somaRich wrote:Fitted mine and took some shots but I didn't have anything to compare them to as i had no shot of the old tube.
My old tube was dull so i fitted a new one but it was just as dull and then i found it was because the contacts needed cleaning. After that, even the old one gave really good light - easily enough to read by. So i've had a spare tube for 7 years now!
Return to “Pimp My Bongo”
