spraying mirrors
Moderator: Ian
peanutcrusher
spraying mirrors
Post by peanutcrusher » Sat Mar 15, 2014 6:37 pm
Has anyone here resprayed their mirrors?
if so did you undercoat them first or just spray them.
Bongo now work later !!! :) :)
The Great Pretender
Re: spraying mirrors
Post by The Great Pretender » Sat Mar 15, 2014 11:55 pm
Just sprayed mine, no problems. :wink:
To infinity and beyond
Simon Jones
Post by Simon Jones » Sat Mar 15, 2014 11:59 pm
Can you see anything with them now? :)
dom_e
Post by dom_e » Sun Mar 16, 2014 6:33 pm
I imagine that you'd need to sand and de grease them, then prime them with plastic primer, before applying the paint and lacquer.
Beyond A to B
stuc
Post by stuc » Sun Mar 16, 2014 10:49 pm
Depends if they are painted already, if so just sand down P800 wet or dry or p500 dry free cut paper and red scotchbrite. Only need priming if you sand through the original paint.
If they are bare plastic, rub with red scotchbrite, thorougly clean, apply plastic adhesion primer, then prime with either wet on wet primer and then paint or some high build primer, dry, then sand with P800 wet or dry or P500 dry free cut paper. Clean again then apply paint of your choice.
The Great Pretender
Post by The Great Pretender » Tue Mar 18, 2014 12:20 am
stuc wrote:Depends if they are painted already, if so just sand down P800 wet or dry or p500 dry free cut paper and red scotchbrite. Only need priming if you sand through the original paint.
Sound advice, but alI I did was wet n dry the bare plastic and 2 pack them, only done 12 months ago but no problems. It was done as an afterthought while doing some repair work.
The Great Pretender
Post by The Great Pretender » Tue Mar 18, 2014 12:24 am
Simon Jones wrote:Can you see anything with them now? :)
:lol: :lol: :lol: I don’t look in them any more to scary, Just wear a neck brace waiting for the next muppet to run in the back of the Bongo...... :shock: :lol: :wink:
Return to “Pimp My Bongo”
